September 4, 2017, 03:59 |
OF v1706: Problem with Overset
Rep Power: 9 |
Hi all!
I´m doing a simulation with overset meshes. I ran already the tutorials that come with the new version v1706. Till some of the first time steps it seemes alright, but then i get a problem with the overset analysis( see part of the log-file) logfile: PIMPLE: iteration 1 DILUPBiCGStab: Solving for p, Initial residual = 0.02883, Final residual = 9.8924e-07, No Iterations 101 time step continuity errors : sum local = 1.9287e-11, global = 5.2236e-12, cumulative = -1.9194e-10 DILUPBiCGStab: Solving for p, Initial residual = 0.0030687, Final residual = 9.4395e-07, No Iterations 83 time step continuity errors : sum local = 1.7254e-11, global = -1.2876e-11, cumulative = -2.0482e-10 smoothSolver: Solving for epsilon, Initial residual = 0.044259, Final residual = 7.0462e-07, No Iterations 1 bounding epsilon, min: -224.35 max: 55707 average: 130.87 smoothSolver: Solving for k, Initial residual = 0.026315, Final residual = 4.6123e-07, No Iterations 1 bounding k, min: -0.058255 max: 39.248 average: 0.17978 ExecutionTime = 265.99 s ClockTime = 269 s Courant Number mean: 0.0056557 max: 10.001 deltaT = 3.3825e-05 Time = 0.000996883 inverseDistance : detected 2 mesh regions zone:0 nCells:40476 voxels57 57 57) bb-0.66432 0.2355 -0.645) (1.3357 1.2355 -0.145) zone:1 nCells:332945 voxels57 57 57) bb-0.15859 0.4506 -0.46) (0.36683 0.74074 -0.33) Overset analysis : nCells : 373421 calculated : 363413 interpolated : 9264 (interpolated from local:3364 mixed local/remote:29 remote:5871) hole : 744 PIMPLE: iteration 1 DILUPBiCGStab: Solving for p, Initial residual = 0.024191, Final residual = 8.6156e-07, No Iterations 85 time step continuity errors : sum local = 1.6103e-11, global = -7.3635e-13, cumulative = -2.0555e-10 DILUPBiCGStab: Solving for p, Initial residual = 0.0023978, Final residual = 8.8674e-07, No Iterations 45 time step continuity errors : sum local = 1.6293e-11, global = -1.2992e-11, cumulative = -2.1854e-10 smoothSolver: Solving for epsilon, Initial residual = 0.042515, Final residual = 6.8282e-07, No Iterations 1 bounding epsilon, min: -159.62 max: 66858 average: 129.59 smoothSolver: Solving for k, Initial residual = 0.025049, Final residual = 4.4227e-07, No Iterations 1 bounding k, min: -0.089723 max: 40.213 average: 0.17932 ExecutionTime = 277.5 s ClockTime = 281 s Courant Number mean: 0.0056548 max: 10.003 deltaT = 3.3815e-05 Time = 0.0010307 inverseDistance : detected 2 mesh regions zone:0 nCells:40476 voxels57 57 57) bb-0.66432 0.2355 -0.645) (1.3357 1.2355 -0.145) zone:1 nCells:332945 voxels57 57 57) bb-0.1581 0.45058 -0.46) (0.367 0.741 -0.33) Overset analysis : nCells : 373421 calculated : 325906 interpolated : 10793 (interpolated from local:3937 mixed local/remote:79 remote:6777) hole : 36722 As you can see, in the beginning the number of cells defined as "hole" is around 750, but then it switches immediately to 36700. That means all the cells in the surrounding mesh are also defined as hole. Does anybody have an idea what the reason could be? Best Regards Flo |
September 4, 2017, 08:53 |
Rep Power: 9 |
It seems to be a 2d->3d problem.
I did the same tutorials, which are 2d cases, as a 3d case. And now i have the same problem also in the tutorials..... does anyone have an idea, what could be wrong? Regards Flo |
September 5, 2017, 08:29 |
Rep Power: 9 |
I have solved the problem.
First mistake: the overset patch had some overlapping elements. Second mistake: The background mesh was to coarse. Now it runs fine Best Regards Flo |
September 5, 2017, 15:28 |
Ernesto
Rep Power: 15 |
Hello:
I am trying out the overset implementation in the same openfoam release as you posted. I am trying to model a 2D cilynder-piston assembly but so far I have not been able to figure out how to properly define the "hole " in my case. The problem is that my overset mesh is defined in such a way that no holes need to be cut for it. Rather, the hole needs to be cut for the background mesh. In the attached figure the grid with red cells is supposed to be the boundary fitted overset mesh for the piston. With the moving piston wall on the right hand side of the domain. The hole then need to be defined as the region between this moving piston wall, and the background blue grid. So far I have tried the using the "simplerotor" tutorial example but the hole is not defined correctly as you can see from the "celltypes" field in the attached image. Could you take a look an see if you can help setting up the case? Thanks in advance |
September 20, 2017, 09:07 |
Rep Power: 9 |
Sorry for the late response .....
Did you already solve your problem? CellType 0..... calculated CellType 1..... interpolated CellType 2..... hole So in your picture i´m not missing the holes. I´m missing the interpolated cells. Best Regards Flo |
September 21, 2017, 00:28 |
the problem of overset meshes.
倪
Rep Power: 9 |
I have the same problem of this.
logfile: IMPLE: iteration 1 DICPCG: Solving for cellDisplacementx, Initial residual = 1, Final residual = 3.70390364717e-07, No Iterations 19 DICPCG: Solving for cellDisplacementy, Initial residual = 0, Final residual = 0, No Iterations 0 inverseDistance : detected 2 mesh regions zone:0 nCells:600 voxels30 30 1) bb-2.69443871706e-06 -2.69443871706e-06 -2.69443871706e-06) (2.50000269444 1.00000269444 0.100002694439) zone:1 nCells:300 voxels30 30 1) bb0.249999285857 0.249999285857 -7.14142842854e-07) (0.750000714143 0.750000714143 0.100000714143) Overset analysis : nCells : 900 calculated : 600 interpolated : 300 (interpolated from local:300 mixed local/remote:0 remote:0) hole : 0 As you can see, why my hole's number is “0” ? Anyone can help me? any suggestion would be appreciated. Last edited by nixiaonan; September 21, 2017 at 06:02. |
September 22, 2017, 17:07 |
#7 | |
Ernesto
Rep Power: 15 |
Yes, i already solved it. The problem was not the missig the overset patches, they were setup correctly. The problem was setting up the hole patches correctly. Thanks. |
September 22, 2017, 17:09 |
#8 | |
Ernesto
Rep Power: 15 |
of the intended overset/hole patches. If you follow the tutorials you can quickly realize that the trick is defining correctly the hole patches which is done via topoSet |
September 23, 2017, 23:42 |
thank you very much. can you help me have a look at the case?
#9 | |
倪
Rep Power: 9 |
I have attach my case named tut-2.zip . at next post. |
September 24, 2017, 00:02 |
#10 |
倪
Rep Power: 9 |
logfile: IMPLE: iteration 1 DICPCG: Solving for cellDisplacementx, Initial residual = 1, Final residual = 3.70390364717e-07, No Iterations 19 DICPCG: Solving for cellDisplacementy, Initial residual = 0, Final residual = 0, No Iterations 0 inverseDistance : detected 2 mesh regions zone:0 nCells:600 voxels30 30 1) bb-2.69443871706e-06 -2.69443871706e-06 -2.69443871706e-06) (2.50000269444 1.00000269444 0.100002694439) zone:1 nCells:300 voxels30 30 1) bb0.249999285857 0.249999285857 -7.14142842854e-07) (0.750000714143 0.750000714143 0.100000714143) Overset analysis : nCells : 900 calculated : 600 interpolated : 300 (interpolated from local:300 mixed local/remote:0 remote:0) hole : 0 As you can see, why my hole's number is “0” ? Anyone can help me? any suggestion would be appreciated. |
September 25, 2017, 03:49 |
#11 |
Rep Power: 9 |
@nixiaonan: Is your "hole" patch a closed surface? it seems the sover doesn´t recognize it to cut it out. can you post a picture?
I´m having a new problem now My case runs just fine, and then after some random time it crashes without any reason i could imagine. Did anyone already had that problem? see attached logfile Best Regards Flo |
September 25, 2017, 22:15 |
#12 | |
倪
Rep Power: 9 |
September 25, 2017, 22:16 |
#13 | |
倪
Rep Power: 9 |
September 27, 2017, 09:23 |
#14 | |
倪
Rep Power: 9 |
December 24, 2017, 21:14 |
The same problem
#15 | |
jingyuanli
Rep Power: 9 |
I have the same problem in my tutorials.in the beginning the number of cells defined as "hole" is around 2808, But when it comes to 4.8 seconds ,then it switches to 284210. I want to know (1)what's meaning about the overset patch had some overlapping elements???can you detailed explanation about it?? (2)Can you share your experience with the relation between background mesh and rigid mesh size? thanks Best Regrads Li |
January 24, 2018, 12:39 |
#16 |
Rep Power: 9 |
Hi.
My case was not working when the background mesh was to coarse compared to the rotating mesh. But i cannot tell you a ratio which you should have. In the end i chose the same mesh size in that area, where i have my overset mesh. And then it worked. I guess i could have made it a bit coarser, but i didn´t try. Concerning the overlapping elements, i do not remember anymore. Sorry for that Best regards Flo |
August 11, 2018, 02:47 |
overset master patch issue
#17 |
Harish K G
Rep Power: 8 |
Hi ,
I too have issue with openfoam overset mesh , as i get warning of master overset patch should be the first patch.. and i dont whether it is affecting my results.. I have attached the images of the result..the interpolation is not happening between the overset boundary and the background.. |
October 8, 2018, 10:21 |
#18 | |
Alessandro Palmas
Rep Power: 12 |
I basically used the overSimpleFoam tutorial case (aerofoil) and extended it to a 3D setting, defining regions using the topoSet functionality as it is done in that tutorial. But when overSimpleFoam starts it writes cellTypes (0, 1 and 2, that are respectively calculated, interpolated and holes) in a weird way, where the background mesh has all cells of cellType 2 (holes), so I believe this is the reason. But I don't know how to fix this, since no tutorial case is using 3D geometry files as my case, and the only way to define regions I can infer from tutorials is to use topoSet with a regionToCell using the point in the background for the first region, and the other region performing the inverse of the first one. Does anyone have any advice about how to deal with 3D geometries? Thanks a lot |
October 9, 2018, 05:17 |
more on this
#19 |
Alessandro Palmas
Rep Power: 12 |
Let me add few details to be more clear:
I tried a very basic setup, extending the tutorial aerofoil for overSimpleFoam from 2D to a 3D setting. It is all explained in the following image: I have a valve plate inside an overset mesh that I want to add to a simple channel background mesh. But what I am finding is that, if I enclose my plate inside a STL cube (or blockmesh base) to delimit the external boundary of the overset mesh, everything goes well, while if I enclose my plate in a STL cylinder to delimit with it the external boundary of the overset mesh, when I run overSimpleFoam it wrongly deduces the cellType, it basically sees an additional wall at the overset Mesh external limit. The image explains it quite well. Few notes: 1) If I use the STL cube to delimit the overset mesh or simply blockmesh it goes well 2) It is not a matter of snapping, the cube is snapped and I also tried to use castellated mesh for the cylinder but it still has the same problem 3) I need to use a STL defined external boundary for the overset mesh because it has to fit my internal geometries 4) I have been setting ZoneID using topoSet+setFields and it works correctly (apparently), in the sense that the two zones appears to be correctly separated See the image (also in the attached pdf file) I believe it is either a stupid mistake or a non-intuitive (wrong) behavior of the code... Last edited by alpha23; October 9, 2018 at 07:24. |
March 16, 2021, 03:27 |
#20 |
Rep Power: 6 |
Hi Alessandro,
I'm into a case with 3D overset mesh and having the same problem. The celltypes are automatically detected in a wrong way though the zoneID are set correctly. Have you figured out any solutions? Any help will be appreciated! |
[Other] engineFoam new mesh problem | ayhan515 | OpenFOAM Meshing & Mesh Conversion | 5 | August 10, 2015 09:45 |
Mixture model problem - could someone please advise? | matlab_monkey | FLUENT | 2 | July 26, 2012 09:20 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 05:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 06:59 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 20:13 |
