Error while compiling using wmake of a finite volume method. |
R.B.
Rep Power: 9 ![]() |
Hi All,
I have downloaded a solver (SbmFoam) that was created around 2012 (exact OF version is unknown). While compiling in the OF5, I have found several issues while compiling. The first modification I made was to include the following lines to Make/options file: However now when I run Code:
wmake Code:
.......5.0/run/SbmFoam$ wmake Making dependency list for source file SbmFoam.C g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam5/src/finiteVolume/lnInclude -I/opt/openfoam5/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam5/src/OpenFOAM/lnInclude -I/opt/openfoam5/src/OSspecific/POSIX/lnInclude -fPIC -c SbmFoam.C -o Make/linux64GccDPInt32Opt/SbmFoam.o SbmFoam.C: In function ‘int main(int, char**)’: SbmFoam.C:105:31: error: ‘nCorr’ was not declared in this scope for (int corr=0; corr<nCorr; corr++) ^ SbmFoam.C:118:26: error: passing ‘const Foam::fvMatrix<Foam::Vector<double> >’ as ‘this’ argument discards qualifiers [-fpermissive] UEqn().relax(); ^ In file included from /opt/openfoam5/src/finiteVolume/lnInclude/fvMatrix.H:1061:0, from /opt/openfoam5/src/finiteVolume/lnInclude/ddtScheme.C:29, from /opt/openfoam5/src/finiteVolume/lnInclude/ddtScheme.H:342, from /opt/openfoam5/src/finiteVolume/lnInclude/fvcDdt.C:28, from /opt/openfoam5/src/finiteVolume/lnInclude/fvcDdt.H:205, from /opt/openfoam5/src/finiteVolume/lnInclude/fvc.H:44, from /opt/openfoam5/src/finiteVolume/lnInclude/fvCFD.H:8, from SbmFoam.C:45: /opt/openfoam5/src/finiteVolume/lnInclude/fvMatrix.C:674:6: note: in call to ‘void Foam::fvMatrix<Type>::relax() [with Type = Foam::Vector<double>]’ void Foam::fvMatrix<Type>::relax() ^ SbmFoam.C:122:44: error: passing ‘const Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Boundary’ as ‘this’ argument discards qualifiers [-fpermissive] p.boundaryField().updateCoeffs(); ^ In file included from /opt/openfoam5/src/OpenFOAM/lnInclude/GeometricField.C:1352:0, from /opt/openfoam5/src/OpenFOAM/lnInclude/GeometricField.H:660, from /opt/openfoam5/src/OpenFOAM/lnInclude/GeometricScalarField.H:38, from /opt/openfoam5/src/OpenFOAM/lnInclude/GeometricFields.H:34, from /opt/openfoam5/src/finiteVolume/lnInclude/volFields.H:37, from /opt/openfoam5/src/finiteVolume/lnInclude/surfaceInterpolationScheme.C:27, from /opt/openfoam5/src/finiteVolume/lnInclude/surfaceInterpolationScheme.H:307, from /opt/openfoam5/src/finiteVolume/lnInclude/surfaceInterpolate.H:41, from /opt/openfoam5/src/finiteVolume/lnInclude/fvc.H:39, from /opt/openfoam5/src/finiteVolume/lnInclude/fvCFD.H:8, from SbmFoam.C:45: /opt/openfoam5/src/OpenFOAM/lnInclude/GeometricBoundaryField.C:399:6: note: in call to ‘void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::updateCoeffs() [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh]’ void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary:: ^ SbmFoam.C:133:42: error: ‘nNonOrthCorr’ was not declared in this scope for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++) ^ /opt/openfoam5/wmake/rules/General/transform:25: recipe for target 'Make/linux64GccDPInt32Opt/SbmFoam.o' failed make: *** [Make/linux64GccDPInt32Opt/SbmFoam.o] Error 1 I am new to OpenFOAM and I was wondering if anyone can guide towards the right direction to troubleshoot this issue with this code. If it is any help, I am running Ubuntu 16.04(guest) on a VirtualBox Windows 10(host). Many thanks. |
cfd - post, wmake error, wmake problems |
Lattice Boltzmann method vs Finite Element Method and Finite Volume Method | solemnpriest | Main CFD Forum | 3 | August 12, 2013 11:00 |
Finite Volume Method | cfd seeker | Main CFD Forum | 3 | September 8, 2011 04:36 |
OpenFOAM15 installables are incomplete problem with paraFoam | tryingof | OpenFOAM Bugs | 17 | December 7, 2008 04:41 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
