Test case twoLiquidMixingFoam
Old   August 31, 2017, 07:48
Default Test case twoLiquidMixingFoam
Gearb0x is on a distinguished road
Dear Foamers,
I am trying to validate a case of Hydrogen or Helium diffusion inside air. The current setup is considering Helium properties (although the phase is called Hydrogen in the case) assuming laminar flow.
Geometry is a simple cube but solved in 2D, so a square.
Pressure is uniform, velocity field is zero everywhere.
Only the Helium fraction is set to 1.0 in the upper part of the Mesh. Setfields utility is used to set Helium fraction to 1.0 in a defined box.
Around 400 seconds, it seems an instability is appearing (at least, i don't expect a flow driven mainly by pure diffusion to behave like that) but I don't know enough in CFD to understand exactly what is going on.
Could someone maybe give me a hint on what is happening ?
Gearb0x is offline   Reply With Quote
Old   September 1, 2017, 02:44
Ok the issue was apparentely the timeStep (deltaT) in controlDict being too large.
The residuals in the log file seemed ok but analyzing them through foamLog log utility and then plotting revealed an issue. Decreasing the timeStep solved the issue. Now to find how to find a way determine the timestep optimally because Courant number seemed ok.
Old   September 8, 2017, 13:53
Thomas Evans
windscion is on a distinguished road
Well starting at rest the courant number isn't gonna mean much.
Did you estimate the Brunt–Väisälä buoyancy frequency? That should be more helpful here.
windscion is offline   Reply With Quote
[DesignModeler] DesignModeler Scripting: How to get Full Command Access ANT ANSYS Meshing & Geometry 53 February 16, 2020 16:13
Need a 3D unstaedy test case for code validation usyusuf Main CFD Forum 0 February 14, 2014 14:53
Viscositymodel tutorial, problems when changing test case to cavity sur4j OpenFOAM Programming & Development 1 December 8, 2013 10:53
rhoSimpleFoam - test case atareen64 OpenFOAM Running, Solving & CFD 5 May 1, 2011 18:17
Porous Media test case Alex FLUENT 0 April 9, 2006 09:23
