August 31, 2017, 02:18 |
Problem in waves2Foam running
Pooja Verma
Rep Power: 9 |
Hi Foamers,
I have a problem that whenever i run the Allrun file, the gets deleted and bin file also gets deleted and the log file appear which say command not found. I have tried to enter the commands separately but it doesn't work and the parafoam operation also doesn't work. I am attaching my Allrun and bin file . OpenFOAM2.3.0 AND UBUNTU14.04 Last edited by PVERMA; September 1, 2017 at 02:02. Reason: versino of openFoam |
September 1, 2017, 19:33 |
Sugajen
Rep Power: 14 |
Hi Pooja,
Could you please attach the solver and the case files ? best, Sugajen |
September 4, 2017, 02:12 |
regarding waves2Foam
Pooja Verma
Rep Power: 9 |
Hi Sugajen,
Iam attaching the Solver and the case Files . I am using OpenFoam2.3.0 . Regard , Pooja |
related to wavefoam |
ANSYS Licensing Problem, Processes Running but Showing as Not Running | penguinman | ANSYS | 3 | September 27, 2016 14:30 |
[Other] Problem running after decomposition | paul.m.edwards | OpenFOAM Meshing & Mesh Conversion | 0 | January 14, 2015 13:55 |
Problem while running in Highperformance computing environment | Phanipavan | STAR-CD | 1 | September 11, 2013 07:42 |
problem with running in parallel | dhruv | OpenFOAM | 3 | November 25, 2011 06:06 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 08:52 |
