August 29, 2017, 19:04 |
simpleFooUnable to find initial target face
Vedamt Chittlangia
Rep Power: 9 |
I am simulating flow past an airfoil in OpenFOAM. I have created the mesh in Pointwise and then exported it as CAE from Pointwise. I have the following boundary conditions: INLET -> fixedValue OUTLET -> zeroGradient; Periodic_1 -> cyclicAMI, neighbourPatch Periodic_2; Periodic_2 -> cyclicAMI , neighbourPatch Periodic_1; frontAndBack -> Empty; CS -> wall; I checked the mesh using checkMesh and found it to be OK. But when I run the simulation using Code:
simpleFoam Code:
Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi AMI: Creating addressing and weights between 453 source faces and 387 target faces --> FOAM Warning : From function AMIMethod<SourcePatch, TargetPatch>::checkPatches() in file lnInclude/AMIMethod.C at line 57 Source and target patch bounding boxes are not similar source box span : (1.552 0.796554 0.0388) target box span : (1.552 0.796554 0.0388) source box : (-0.430502 -0.0584186 0) (1.1215 0.738135 0.0388) target box : (-0.430502 -0.515211 0) (1.1215 0.281343 0.0388) inflated target box : (-0.517747 -0.602456 -0.0872454) (1.20874 0.368588 0.126045) --> FOAM FATAL ERROR: Unable to find initial target face From function void Foam::AMIMethod<SourcePatch, TargetPatch>::initialise(labelListList&, scalarListList&, labelListList&, scalarListList&, label&, label&) in file lnInclude/AMIMethod.C at line 149. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) in "/gpfs/home/vjc5126/work//OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::error::abort() in "/gpfs/home/vjc5126/work//OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 Foam::AMIMethod<Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> >, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > >::initialise(Foam::List<Foam::List<int> >&, Foam::List<Foam::List<double> >&, Foam::List<Foam::List<int> >&, Foam::List<Foam::List<double> >&, int&, int&) in "/gpfs/home/vjc5126/work//OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libmeshTools.so" #3 Foam::faceAreaWeightAMI<Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> >, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > >::calculate(Foam::List<Foam::List<int> >&, Foam::List<Foam::List<double> >&, Foam::List<Foam::List<int> >&, Foam::List<Foam::List<double> >&, int, int) in "/gpfs/home/vjc5126/work//OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libmeshTools.so" #4 Foam::AMIInterpolation<Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> >, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > >::update(Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&) in "/gpfs/home/vjc5126/work//OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libmeshTools.so" #5 Foam::AMIInterpolation<Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> >, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > >::constructFromSurface(Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, Foam::autoPtr<Foam::searchableSurface> const&) in "/gpfs/home/vjc5126/work//OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libmeshTools.so" #6 Foam::AMIInterpolation<Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> >, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > >::AMIInterpolation(Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, Foam::autoPtr<Foam::searchableSurface> const&, Foam::faceAreaIntersect::triangulationMode const&, bool, Foam::AMIInterpolation<Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> >, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > >::interpolationMethod const&, double, bool) in "/gpfs/home/vjc5126/work//OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libmeshTools.so" #7 Foam::cyclicAMIPolyPatch::resetAMI(Foam::AMIInterpolation<Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> >, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > >::interpolationMethod const&) const in "/gpfs/home/vjc5126/work//OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libmeshTools.so" #8 Foam::cyclicAMIPolyPatch::AMI() const in "/gpfs/home/vjc5126/work//OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libmeshTools.so" #9 Foam::cyclicAMIPolyPatch::applyLowWeightCorrection() const in "/gpfs/home/vjc5126/work//OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libmeshTools.so" #10 Foam::cyclicAMIFvPatch::makeWeights(Foam::Field<double>&) const in "/gpfs/home/vjc5126/work//OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #11 Foam::surfaceInterpolation::makeWeights() const in "/gpfs/home/vjc5126/work//OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #12 Foam::surfaceInterpolation::weights() const in "/gpfs/home/vjc5126/work//OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #13 Foam::tmp<Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::linearInterpolate<Foam::Vector<double> >(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) in "/gpfs/home/vjc5126/work/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/bin/simpleFoam" #14 ? in "/gpfs/home/vjc5126/work/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/bin/simpleFoam" #15 __libc_start_main in "/lib64/libc.so.6" #16 ? in "/gpfs/home/vjc5126/work/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/bin/simpleFoam" Aborted (core dumped) Here is the link to the case: case Thanks, Vedant Update: I re-checked the geometry and the periodic BCs have the same area and shape Last edited by vcvedant; August 29, 2017 at 21:58. Reason: update |
August 29, 2017, 22:34 |
Vedamt Chittlangia
Rep Power: 9 |
I am able to get resolve this issue by adding in the constant/polyMesh/boundary:
Periodic_1 { type cyclicAMI; : : transform translational; separationVector (0 0.4567923 0); } But now the when I run the simpleFoam, I get 'nan' in the first iteration for p. |
August 30, 2017, 09:48 |
Vedamt Chittlangia
Rep Power: 9 |
Another update: I changed the solver type for p and the simulation proceeds further but got very high continuity errors, 10^28. Then I ran the case in laminar and let the velocity field develop. Thereafter I turned on the turbulence and the continuity errors decreased.
I will update this post if I am able to solve this post and get results as per some previous studies in FLUENT and CFX. PS: Please feel free if anyone wants to give their inputs. Thanks |
September 6, 2018, 10:43 |
Thomas M
Rep Power: 8 |
Any more details on this? I have the same error:
Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 0.0001 field Ux tolerance 0.0001 field Uy tolerance 0.0001 field k tolerance 0.0001 field epsilon tolerance 0.0001 Reading field p AMI: Creating addressing and weights between 76 source faces and 76 target faces --> FOAM Warning : From function void Foam::AMIMethod<SourcePatch, TargetPatch>::checkPatches() const [with SourcePatch = Foam::PrimitivePatch<Foam::face, Foam::SubList, const Foam::Field<Foam::Vector<double> >&>; TargetPatch = Foam::PrimitivePatch<Foam::face, Foam::SubList, const Foam::Field<Foam::Vector<double> >&>] in file lnInclude/AMIMethod.C at line 57 Source and target patch bounding boxes are not similar source box span : (0.164987 0.0569055 0.0005) target box span : (0.164987 0.0569055 0.0005) source box : (-0.186475 0.0302639 0) (-0.0214882 0.0871693 0.0005) target box : (-0.186475 -0.141037 0) (-0.0214882 -0.0841312 0.0005) inflated target box : (-0.195201 -0.149763 -0.00872627) (-0.0127619 -0.0754049 0.00922627) --> FOAM FATAL ERROR: Unable to find initial target face From function bool Foam::AMIMethod<SourcePatch, TargetPatch>::initialise(Foam::labelListList&, Foam::scalarListList&, Foam::labelListList&, Foam::scalarListList&, Foam::label&, Foam::label&) [with SourcePatch = Foam::PrimitivePatch<Foam::face, Foam::SubList, const Foam::Field<Foam::Vector<double> >&>; TargetPatch = Foam::PrimitivePatch<Foam::face, Foam::SubList, const Foam::Field<Foam::Vector<double> >&>; Foam::labelListList = Foam::List<Foam::List<int> >; Foam::scalarListList = Foam::List<Foam::List<double> >; Foam::label = int] in file lnInclude/AMIMethod.C at line 127. FOAM aborting Last edited by tmik; September 10, 2018 at 08:16. |
May 13, 2019, 03:29 |
separationVector
Vishnu
Rep Power: 7 |
Hi all,
May i know how to define value for separationVector in createPatchDict ? Thanks in advance, Vishsel. |
July 11, 2019, 21:07 |
#6 | |
Neilson Whit
Rep Power: 15 |
surface1 surface2 at (-2 0 0) at (2 0 0) | ---------------------> | the separation vector for your surface1 will be (4 0 0) which shows that your neighbour surface surface2 separated from your reference surface1 with that vector. |
July 12, 2019, 09:33 |
Thanks
Thomas M
Rep Power: 8 |
Thanks Wolfinthedark! I had no idea, but you are correct.
I was using the vector from the origin instead of between surfaces (or in my case edges) Code:
Wrong way: |<--------------------.------------------->| [vector: (0 -2 0)] surface1 origin surface2 [vector: (0 2 0)] _________________________________________________________ Correct way: |--------------------------------------->| surface1 surface2 [vector: (0 4 0)] |<---------------------------------------| surface1 surface2 [vector: (0 -4 0)] |
airfoil 2d, cyclic boundary, cyclicami, periodic bc |
Maximum number of iterations exceeded chtmultiregionsimpleFoam | Moncef | OpenFOAM Running, Solving & CFD | 28 | July 13, 2020 14:26 |
Problem Building OF on Centos cluster (no admin rights) | CKH | OpenFOAM Installation | 5 | November 13, 2011 06:32 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 12:50 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
