rhoPimpleFoam - Maximum number of iterations exceeded |
August 29, 2017, 05:50 |
kalei
Rep Power: 12 |
Hallo,
when running rhoPimpleFOAM to simulate a high mach number compressible gas flow I get the following error: PIMPLE: iteration 1 smoothSolver: Solving for Ux, Initial residual = 0.01727963417, Final residual = 9.70350519e-07, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.002102322572, Final residual = 9.666745303e-08, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 0.01773571813, Final residual = 3.83106408e-08, No Iterations 4 DILUPBiCG: Solving for h, Initial residual = 0.03497107833, Final residual = 1.879401836e-06, No Iterations 2 0] [2] [2] [2] --> FOAM FATAL ERROR: [2] Maximum number of iterations exceeded [2] [2] From function thermo<Thermo, Type>::T(scalar f, scalar T0, scalar (thermo<Thermo, Type>::*F)(const scalar) const, scalar (thermo<Thermo, Type>::*dFdT)(const scalar) const, scalar (thermo<Thermo, Type>::*limit)(const scalar) const) const I already tested a lot of things. E.g. by changing nOuterCorrectors, nCorrectors and tolerances I can delay the error. However, I did not succeed to completely prevent it. Can anybody give me a hint what is the origin of the error and how I can prevent it. Best kalei |
September 8, 2017, 14:00 |
Thomas Evans
Rep Power: 11 |
Despite the flow and h being okay, it might yet be a grid problem. More likely, it could be a boundary condition problem. Since each field has different BCs, that seems more likely.
Also, when in doubt, try reducing dt. |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 08:56 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 03:50 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 19:17 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 14:12 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 14:58 |
