multiMotion in solidBodyMotion using icoDyMFoam and icoDyMIbFoam
Old   August 28, 2017, 20:59
Default multiMotion in solidBodyMotion using icoDyMFoam and icoDyMIbFoam
Engineers is on a distinguished road
Hello all,
I've been trying for a while to combine the pitching and heaving motion using either icoDyMIbFoam or icoDyMFoam solvers with little success. I'm using Foam-ext-3.2 and I have successfully ran the pitching and heaving cases separately.
Here's what I have tried:
[[1]] Case I
| \\ / F ield | foam-extend: Open Source CFD |
| \\ / O peration | Version: 3.2 |
| \\ / A nd | Web: http://www.foam-extend.org |
| \\/ M anipulation | For copyright notice see file Copyright |
FoamFile
version 2.0;
format ascii;
class dictionary;
object dynamicMeshDict;
dynamicFvMesh solidBodyMotionFvMesh;
solidBodyMotionFvMeshCoeffs
solidBodyMotionFunction multiMotion;
motionFunctions
trisurf
multiMotionCoeffs
PitchingMove
solidBodyMotionFunction rotatingOscillation;
rotatingOscillationCoeffs
origin (0 0 0);
amplitude (0 0 8);
amplitude0 (0 0 0);
period 1.3918;
FlappingMove
solidBodyMotionFunction linearOscillationCoeffs;
origin (0 0 0);
amplitude (0 0.15 0);
amplitude0 (0 0 0);
period 1.3918;
motionSolverLibs ( "libfvMotionSolvers.so" );
However, this fails with the error that:
--> FOAM FATAL ERROR:
Unknown solidBodyMotionFunction type multiMotion
Valid solidBodyMotionFunctions are :
5
SDA
SKA
linearOscillation
rotatingOscillation
translation
From function solidBodyMotionFunction::New( const dictionary& SBMFCoeffs, const Time& runTime)
in file solidBodyMotionFunction/newSolidBodyMotionFunction.C at line 54.
FOAM exiting
[[2]] Case II
I've tried using SDA to run this, but I cannot get the Roll to be zero. I would only need pitching (sway) and heaving motion.
I am for sure doing something wrong, but I don't seem to be getting anywhere with trial and error here. Any help would be greatly appreciated.
Thanks,
AH
Engineers is offline   Reply With Quote
Old   November 14, 2021, 06:14
Amirhossein Taran
amirhosseintaran is on a distinguished road
Hi AH,
Did you found any solution for it so far ?
Regards.
Amir
amirhosseintaran is offline   Reply With Quote
Old   July 9, 2023, 10:10
Grp
GrpOne123 is on a distinguished road
Hello, I make the icoDyMIbFoam from pimpleDyMIbFoam but when I calculate a toturial it will take some problem about pcorr solution singularity.
Can you tell me how did you make the icoDyMIbFoam?
GrpOne123 is offline   Reply With Quote
ibm, moving mesh., multimotion, sda
