Leila
Rep Power: 0 ![]() |
Hello!
I'm simulating a surface piercing propeller by using tutorial->MultiPhase->interPhaseChangeDyMFoam. I use a Mesh file (.msh) for the geometry of the propeller and I convert it to Foam format by using Fluent3DMeshToFoam. And I also disable propeller movement (commented all lines in DynamicMeshDict and write "dynamicFvMesh staticFvMesh"). But the solver still diverges. and the Courant number increase sharply but suddenly decrease sharply. I tried different methods but I didn't get any results. log.interPhaseChangeDyMFoam is attached.I would be grateful if you could help me.Thank you for taking this into consideration. Bests, Leila |
Retired Super Moderator
Bruno Santos
Rep Power: 128 ![]() ![]() ![]() ![]() ![]() ![]() |
Quick answer: My guess is that the problem is the mesh itself has very small cells where the fluid is the fastest, hence this being part of the problem.
My suggestion is that you use yourself an isolate and conquer approach to solve this, otherwise someone else will have to do it for you. For example:
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 21:00 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
Sudden jump in Courant number | NJG | OpenFOAM Running, Solving & CFD | 7 | May 15, 2014 13:52 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
