Rep Power: 9 ![]() |
I am a BEng student and I am using OpenFoam 3.0.1 to study the movement of a free floating rigid body that is capsizing. I would like to use the restraint sphericalAngularDamper with sixDoFRigidBodyMotion, so I studied the tutorial DTCHull and I added these lines in my dynamicMeshDict : { rotationDamper { sixDoFRigidBodyMotionRestraint sphericalAngularDamper; coeff 11586; } } } However, the results are the same as the case without the rotationDamper. I also tried to use other coefficients, but nothing has changed. Moreover in my log.interDymFoam there aren't these lines that I find in the DTCHull case. " Rotational constraint tensor (0 0 0 0 1 0 0 0 0) .... Restraint rotationDamper: moment (-0 -0 -0) " My feeling is that the input file is not properly read, but I cannot see what I am missing. I would really appreciate some advice on this. Thanks in advance for any help. |
I resolved my problem. In some lines of my dynamicMeshDict there were too many parentheses. |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[mesh manipulation] Problems with rotational cyclic boundaries | TReviol | OpenFOAM Meshing & Mesh Conversion | 8 | July 11, 2014 03:45 |
[ICEM] Flow channel meshing problems | StefanG | ANSYS Meshing & Geometry | 19 | May 15, 2012 06:44 |
Two-phase air water flow problems by activating Wall Lubrication Force | challenger85 | CFX | 5 | November 5, 2009 05:44 |
Help required to solve Hydraulic related problems | aero | CFX | 0 | October 30, 2006 11:00 |
