Solver selection
Old   August 23, 2017, 06:01
Arrow Solver selection
Ketan Ganatra
ketanganatra0@yahoo.com is on a distinguished road
The valid asmmetric solvers are
PBiCG
smoothSolver
GAMG
The valid smmetric solvers are
PCG
If we chose different than the errorr message will appear and also for interchanging with symmetric and asymmetric
I want to knowthat for asymmetric matrix itself if we chose different for asymmetric from above three.
Will it affect the solution???
ketanganatra0@yahoo.com is offline   Reply With Quote
Old   August 24, 2017, 14:59
Klaus
klausb will become famous soon enough
GAMG and smoothSolver can also be used for symmetric matrices.
Based on my experience with external flows, the choice is about speed and stability. PCG + PBiCG is the fastest combination for my cases but at high angles of attack, PBiCG might crash so I have to use another solver for those cases (actually OpenFoam tells me which one to use in the output/log file, when a simulation crashes).
To get exact results, adjust the fvSchemes for your type of simulations. It has a BIG impact on stability and helps to fine-tune results to match experimental results.
Klaus
klausb is offline   Reply With Quote
Hybrid discretisation - blend factor gcoopermax CFX 5 September 23, 2016 09:05
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 17:08
Solver selection for transonic compressor stage in Foam-extend-3.0 dowlee OpenFOAM Running, Solving & CFD 1 April 16, 2015 14:33
Problem in3D model processing mebinitap OpenFOAM 2 December 12, 2014 05:40
Setting a B.C using UserFortran in 4.3 tokai CFX 10 July 17, 2001 17:25
