rhoSimpleFoam convergence issue
Old   August 21, 2017, 06:51
Default rhoSimpleFoam convergence issue
ff
fxzf is on a distinguished road
I am currenlty using rhoSimpleFoam to solve my case which is body with very hot jet flow at rear (temperature of jet flow is around 800K) under low speed flow field Mach < 0.1. rhoSimpleFoam can get results. But residual and CL, Cd are very oscillating.
The p is only get to 0.01 level. The problem is Cl, Cd quantaties is oscillating about 5% which make results hard to use.
The solver for p I used is GAMG with preconditioner. The relaxation I used for rho is 0.01, for p is 0.3.
Does anyone has better idea to improve the convergence, at least to reduce the Cl, Cd oscillation?
Thanks very much.
fxzf is offline   Reply With Quote
Old   August 21, 2017, 10:51
S. Leponiemi
kZaq is on a distinguished road
I recently fought with rhoSimpleFoam too. Oscillations happen pretty much always, because very few compressible cases have a steady-state solution. So your results can ever be only so accurate.
What I did was find the timestep when the solution is close to convergence, but just before it starts to oscillate, and at that timestep drop the relaxation factors significantly. For example, 0.01 for p and rho fields and 0.1 for all equations. This gives results that can be compared reliably from case to case.
The relaxation factors can be modified on the fly
kZaq is offline   Reply With Quote
Old   August 28, 2017, 05:37
ff
Originally Posted by kZaq View Post
Great. Thank very much for your reply. I tried this strategy and it improved a bit but then need a long time to converge.
By the way, do you have any reference paper about rhoSimpleFoam. I want to figure out how this solver works.
Convergence Centurion2011 FLUENT 48 June 15, 2022 00:29
Convergence issue with continuity equation Jake FLUENT 8 June 6, 2018 04:41
convergence issue for transonic turbulent case aeroiitkgp SU2 5 May 12, 2015 17:44
Continuity convergence issue for a multiphase flow in a counterflow heat exchanger Andrea1984 Fluent Multiphase 2 July 24, 2013 05:55
Force can not converge colopolo CFX 13 October 4, 2011 23:03
