How to calculate a Volume of all Cells after using snappyHexMesh |
August 20, 2017, 18:40 |
Joaquin Del Pino
Rep Power: 9 |
Hello everyone.
I'm simulating a bio-filter inside of a room. To generate mesh I used snappyHexMesh. Then I runed the simulation using simpleFoam and I got the velocity and pressure in each cell, but now I need to compute the volume of each cell to calculate the % of volume in that velocity is different from zero. I read a lot of topics in CFD but i don't understand where I must be create codes or use mesh.V(). I would appreciate a detailed explanation Regards. Joaquin Del Pino |
August 22, 2017, 04:02 |
romainRH
Rep Power: 14 |
Hi Joaquin,
You can have a look at the discussion call "cell volume and face area calculation" There is a tar.gz with a utility to compute and write V Romain Sent from my HTC Desire 825 using CFD Online Forum mobile app |
cell, compute volume, volume, volume cell zone |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[snappyHexMesh] snappyHexMesh <-> dynamicMeshDict problem with protected cells | Billy_16 | OpenFOAM Meshing & Mesh Conversion | 2 | November 21, 2020 03:34 |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 06:00 |
Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 02:53 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
