August 10, 2017, 21:22 |
verticalDamping in OF5
Virag Mishra
Rep Power: 12 |
Hi
Can anyone tell how verticalDamping in OF5 works. When I see the code it seems to add a source term of force to damp the U. The log files tells that the cells are selected on every nOuterCorrectors and nCorrectors iterations. This makes it very expensive. I tried to compare two runs with and without vertical damping and turns out. Damping case is 1.2 times slower. |
March 15, 2018, 04:24 |
Rep Power: 12 |
Hi Virag,
i also noticed this source term, do you know how verticalDamping works now? What I expected is to damp the perturbation at the outlet region. I am not sure if this source term works or not. regards |
verticaldamping, vof multiphase, wave |
