Justin Maris L. Natividad
Rep Power: 10 ![]() |
Good pm. I recently upgraded Ubuntu to its latest version. Afterwhich, I tried to run my case file in parafoam. But the picture attached says otherwise. I tried to install Openfoam again,. Running snappyHexMesh is working fine, but when I open is via parafoam command, the it always says segmentation fault (core dumped). I don't know the root cause of this although the upgrade might been the reason for it. I hope someone knows how to fix this. Thank you
[OpenFOAM] an error in Calculator's equation | immortality | ParaView | 12 | June 29, 2021 00:10 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
DPM udf error | haghshenasfard | FLUENT | 0 | April 13, 2016 06:35 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
