oum
Rep Power: 9 ![]() |
I am a new user of OF, I am simulating a rotating hydroturbine using pimpleDyMFoam but I have some issues where the simulation crashes after high Co number value and few iterations. I run the checkMesh, it is okay. If anyone can help me figure out where the problem is, please thank you. For example: Code:
Courant Number mean: 0.0665607 max: 294.314 Time = 0.0035 smoothSolver: Solving for Uz, Initial residual = 0.000988812, Final residual = 8.59295e-07, No Iterations 6 AMI: Creating addressing and weights between 18784 source faces and 18784 target faces smoothSolver: Solving for Ux, Initial residual = 0.00213788, Final residual = 1.06473e-06, No Iterations 5 AMI: Patch source sum(weights) min/max/average = 0.999999, 1.00004, 1.00001 AMI: Patch target sum(weights) min/max/average = 0.997471, 1.00004, 0.999978 smoothSolver: Solving for Uy, Initial residual = 0.00214001, Final residual = 2.03012e-06, No Iterations 4 smoothSolver: Solving for Uz, Initial residual = 0.00257939, Final residual = 1.7967e-06, No Iterations 5 PIMPLE: iteration 1 smoothSolver: Solving for Ux, Initial residual = 0.000304317, Final residual = 5.73925e-07, No Iterations 7 smoothSolver: Solving for Uy, Initial residual = 0.000301525, Final residual = 8.5824e-07, No Iterations 6 smoothSolver: Solving for Uz, Initial residual = 0.000429538, Final residual = 8.4974e-07, No Iterations 7 PIMPLE: iteration 1 smoothSolver: Solving for Ux, Initial residual = 0.0214581, Final residual = 1.67677e-05, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.0214571, Final residual = 1.4444e-05, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 0.0245988, Final residual = 2.12498e-05, No Iterations 3 GAMG: Solving for p, Initial residual = 0.0103925, Final residual = 9.27148e-06, No Iterations 8 time step continuity errors : sum local = 2.14296e-08, global = -2.31864e-09, cumulative = 3.61365e-07 smoothSolver: Solving for Ux, Initial residual = 0.0214581, Final residual = 1.67677e-05, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.0214571, Final residual = 1.4444e-05, No Iterations 3 PIMPLE: iteration 5 smoothSolver: Solving for Uz, Initial residual = 0.0245988, Final residual = 2.12498e-05, No Iterations 3 GAMG: Solving for p, Initial residual = 0.02332, Final residual = 2.00854e-05, No Iterations 7 time step continuity errors : sum local = 4.63087e-08, global = -5.40695e-09, cumulative = 3.63684e-07 PIMPLE: iteration 4 GAMG: Solving for p, Initial residual = 0.00487913, Final residual = 3.59641e-06, No Iterations 7 time step continuity errors : sum local = 8.28061e-09, global = -3.505e-09, cumulative = 3.5786e-07 smoothSolver: Solving for Ux, Initial residual = 0.000304317, Final residual = 5.73925e-07, No Iterations 7 GAMG: Solving for p, Initial residual = 0.023441, Final residual = 1.95274e-05, No Iterations 6 time step continuity errors : sum local = 4.43837e-08, global = -1.11018e-08, cumulative = 3.46758e-07 smoothSolver: Solving for Uy, Initial residual = 0.000301525, Final residual = 8.5824e-07, No Iterations 6 PIMPLE: iteration 2 smoothSolver: Solving for Uz, Initial residual = 0.000429538, Final residual = 8.4974e-07, No Iterations 7 smoothSolver: Solving for omega, Initial residual = 0.000412129, Final residual = 6.34727e-07, No Iterations 4 smoothSolver: Solving for Ux, Initial residual = 0.000718585, Final residual = 6.28164e-07, No Iterations 6 GAMG: Solving for p, Initial residual = 0.023441, Final residual = 1.95274e-05, No Iterations 6 time step continuity errors : sum local = 4.43837e-08, global = -1.11018e-08, cumulative = 3.46758e-07 smoothSolver: Solving for Uy, Initial residual = 0.000718183, Final residual = 5.84072e-07, No Iterations 6 PIMPLE: iteration 2 smoothSolver: Solving for k, Initial residual = 0.0207893, Final residual = 6.86243e-06, No Iterations 3 PIMPLE: not converged within 5 iterations smoothSolver: Solving for Uz, Initial residual = 0.000988812, Final residual = 8.59295e-07, No Iterations 6 smoothSolver: Solving for Ux, Initial residual = 0.00706966, Final residual = 4.63885e-06, No Iterations 6 ExecutionTime = 976.44 s ClockTime = 1035 s |
Sugajen
Rep Power: 14 ![]() |
Hi oumnia,
Welcome to OF! Regarding your question, there could be various reasons for a high Courant number. My quick question now will be did you try setting adjustTimeStep to yes and the max Courant number to a lower value? If your answer is yes, then please do post your boundary conditions, fvSchemes, fvSolutions and other necessary data so that people who can help can get a better hold on the issue. best, Sugajen |
Oskar
Rep Power: 10 ![]() |
Could You show us Your 'checkMesh' report, please? Usually new users misunderstand the report.
How to set two stroke engine with scavenging? Salome, sliding interface and "Zero length edge detected." Last edited by sheaker; August 8, 2017 at 15:38. |
oum
Yes, I did set adjustTimeStep to yes
I attached my boundary conditions Here is my fvSchemes: Code:
ddtSchemes { default Euler; } gradSchemes { default Gauss linear; grad(p) cellLimited Gauss linear 1; grad(U) cellLimited Gauss linear 1; } divSchemes { default none; div(phi,U) Gauss linearUpwind grad(U); div(phi,k) Gauss upwind; div(phi,omega) Gauss upwind; div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear limited corrected 0.5; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default no; pcorr ; p ; } wallDist { method meshWave; } Code:
solvers { pcorr { solver GAMG; tolerance 1e-4; relTol 0.001; nPreSweeps 0; nPostSweeps 2; smoother DICGaussSeidel; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; maxIter 10; } p { $pcorr; tolerance 1e-5; relTol 0.001; maxIter 10; } pFinal { $p; tolerance 1e-6; relTol 0.001; maxIter 10; } "(U|k|omega)" { solver smoothSolver; smoother GaussSeidel; tolerance 1e-6; relTol 0.001; maxIter 20; } "(U|k|omega)Final" { solver smoothSolver; smoother GaussSeidel; tolerance 1e-6; relTol 0.001; maxIter 20; } } PIMPLE { correctPhi no; nOuterCorrectors 5; nCorrectors 1; nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; residualControl { U { tolerance 1e-2; relTol 0.001; } p { tolerance 1e-2; relTol 0.001; } } } relaxationFactors { fields { p 0.7; } equations { "(U|k|omega)" 0.7; "(U|k|omega)Final" 0.7; } } cache { grad(U); } |
PEMFC model with FLUENT | brahimchoice | FLUENT | 22 | April 19, 2020 15:44 |
Floating Point Exception Error | nyox | FLUENT | 11 | November 30, 2018 12:31 |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 07:54 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
Divergence problem | Smaras | FLUENT | 13 | February 21, 2013 05:03 |
