OpenFOAM 5.x: Two conversation issues
Old   August 4, 2017, 10:54
Default OpenFOAM 5.x: Two conversation issues
BastiL
bastil is on a distinguished road
Hello all,
I went from 2.3.x to 5.x and have to say it is much better. In chtMultiRegionFoam everything is more stable.
Two points that are open after case conversation:
1. How to get output of function-objects into the log. In 2.3.x I had "log yes;" as an option in the configuration file but this does not seem to work anymore.
2. Are nonOrthogonalCorrectors still supported by chtMultiRegionFoam? I have the parameters set to 3 for my solids (makes them converge faster), but the solver only does one iteration?
bastil is offline   Reply With Quote
Old   August 5, 2017, 11:49
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
1. https://github.com/OpenFOAM/OpenFOAM...nctionObject.H. "log yes;" should still do the trick. Maybe you add to to wrong dictionary.
2. https://github.com/OpenFOAM/OpenFOAM...MPLEControls.H. nNonOrthogonalCorrectors setting is still there.
alexeym is offline   Reply With Quote
Old   August 8, 2017, 04:30
BastiL
Partially solved. I have a functionObject transfered from 2.3 that is working ("fieldMinMax"-type).
I am struggling with my "flowPatchRate"-types. These are no longer available and I switched to a surfaceFieldValue operation "sum". So this is now a "packed" functionObject and I don't have too much experience with that. It is basically working but "log" does not seem to work.
Working now. I copied a fvSolution file from the snappyHeater-tutorial.
Old   August 8, 2017, 05:18
Alexey Matveichev
To make things easier, could you post your functionObject configuration dictionary? Header comment in $FOAM_SRC/functionObjects/field/fieldValues/surfaceFieldValue/surfaceFieldValue.H contains example of configuration for calculating mass flux across a patch. There it is "log true;", yet it is the same as "log yes;".
Old   August 9, 2017, 10:15
BastiL
Also solved, thanks. Looking into the header file helped me to figure out what parameters are required.
One more question: Is there a easy way to make a function object write out every time-step without explicitly needing to specify them?
Old   August 9, 2017, 13:56
Alexey Matveichev
Unfortunately I was not able to grasp meaning of the last question. I could try to guess, but think it would be easier for everybody if you reformulate the question.
OpenFOAM 4.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 2 October 6, 2017 06:40
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 04:19
[OpenFOAM.org] Having issues installing some features of OPENFOAM on my 32bit OS orobome OpenFOAM Installation 7 March 3, 2015 05:17
enGrid to OpenFOAM full export issues coanda enGrid 1 May 4, 2013 10:31
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
