multiphaseEulerFoam - the velocity fields of phases blows up |
August 4, 2017, 06:32 |
Hello everyone,
I'm trying to simulate a system which consists of three (immiscible) fluids using OpenFOAM 4.0 and the multiphaseEulerFoam solver. The phases are air, "particles" and water. The air and particles are dispersed in the water. The geometry is a rectangle (2D-problem), which contains 2 walls and an inlet and an outlet. The region near the inlet is filled solely by air, while the region near the outlet is occupied by both particles and water, with phase fractions 0.5 and 0.5, respectively. What I'd like to do is as follows: A flow is induced by setting a pressure difference between the inlet and the outlet (pres. diff. ~ 50kPa). The particle phase should not flow through the outlet at all (semi-permeable wall). Hence, only the water phase exits through the outlet and only air should flow in through the inlet to conserve the volume. Intuitively, the phase fraction of the particles should reach 1 at the outlet at some point, and water can no longer exit (the outlet becomes clogged). For some reason though, my velocity fields of all the phases near the phase interface start to blow up after around 0.05 seconds. I've tried various drag force models to no avail, which makes me think my BCs might be incorrect. BCs: p_rgh: FoamFile { version 2.0; format ascii; class volScalarField; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 1e5; boundaryField { inlet { type fixedValue; value $internalField; } outlet { type prghPressure; p uniform 5.0e4; value uniform 5.0e4; } walls { type fixedFluxPressure; value $internalField; } frontAndBackPlanes { type empty; } } and U.air and U.water: FoamFile { version 2.0; format ascii; class volVectorField; object U.air; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type pressureInletOutletVelocity; value $internalField; } outlet { type pressureInletOutletVelocity; value $internalField; } walls { type noSlip; } frontAndBackPlanes { type empty; } } and U.particles: FoamFile { version 2.0; format ascii; class volVectorField; object U.particles; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type zeroGradient; } outlet { type fixedValue; value uniform (0 0 0); } walls { type fixedValue; value uniform (0 0 0); } frontAndBackPlanes { type empty; } } Are these BCs correct for what I'm trying to accomplish? Any other ideas on why the simulation blows up? I'm attaching a minimal case for testing. Any help is greatly appreciated! |
VoF model, two phases, but only able to show velocity of the phase "mixture"? | yulu | FLUENT | 7 | December 25, 2021 09:35 |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 07:08 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
conservative form twoPhaseEulerFoam23x gives an unsatisfactory velocity result. | sharonyue | OpenFOAM Running, Solving & CFD | 12 | April 10, 2016 00:30 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
