reconstructPar/reconstructParMesh in parallel
Like Tree24Likes
Old   August 15, 2017, 10:34
Post
  #21
Armin.Sh is on a distinguished road
Hi Dominic,
Very nice! You are welcome.
No, unfortunately I have no experience with the LSF platform.
Regards,
Armin
Armin.Sh is offline   Reply With Quote
Old   September 2, 2018, 13:20
Default mpiReconstructPar
  #22
Mitja Strakl
mstrakl is on a distinguished road
Dear all,
I have written "quazi" parallel reconstructPar script. Please see the attachment.
Any suggestions where else to post this script, so it will be available to wider community?
Thanks, hope it helps.
Honda likes this.
mstrakl is offline   Reply With Quote
Old   September 10, 2020, 05:33
S A
Propanotriol is on a distinguished road
Originally Posted by Antimony View Post
Yes. In your case folder create an empty/dummy file called (for example) case.foam
In Linux, you could do this by typing "touch case.foam" in the terminal
When you load the case.foam into Paraview, and scroll down under "Properties" you should find one that says "Case Type"
Cheers,
Antimony
Excellent, I was almost crying one hour ago, thank you.
Propanotriol is offline   Reply With Quote
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 05:18
Explicitly filtered LES saeedi Main CFD Forum 16 October 14, 2015 12:58
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
simpleFoam in parallel issue plucas OpenFOAM Running, Solving & CFD 3 July 17, 2013 12:30
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel JR22 OpenFOAM Running, Solving & CFD 2 April 19, 2013 17:49
