Specify an endTime that isn't a multiple of timestep |
August 3, 2017, 06:22 |
James Shaw
Rep Power: 12 |
I need to obtain a solution at a particular simulated time, but I also need to use a timestep that does not divide exactly into endTime. For example, endTime=10s, timestep=3s. I'd like to have solves at t=3s, t=6s, t=9s then, using a timestep=1s, obtain the final solution at t=10s.
Can I configure this in the controlDict and obtain a solution in a single run? |
August 3, 2017, 11:24 |
Joshua
Rep Power: 10 |
You should be fine with an endTime of 10s and a writeTime of 3s as it should automatically write at endTime regardless of writeTime.
I suggest making a small test case that runs in a matter of seconds to test this with your version of OF. Joshua |
August 4, 2017, 05:18 |
#3 | |
James Shaw
Rep Power: 12 |
controldict, timesteps |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
error with smaller timestep ? | Thomas MADELEINE | FLUENT | 0 | August 8, 2016 14:02 |
[OpenFOAM.org] Install openFOAM 3.0.1 in Ubuntu 16.04 LTS from Deb packs | Pier84 | OpenFOAM Installation | 4 | June 18, 2016 17:22 |
obtaining transient results from multiple timestep files | suyesh | FLUENT | 1 | May 13, 2016 10:52 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 13:21 |
