Can anyone explain the change in the code of mixtureKEpsilon turbulence model ? |
#1 | |
Rémi Demol
Rep Power: 10 ![]() |
Hello foamers,
I'm a bit confuse about the different formulations of mixtureKEpsilon models. It seems to me that in the version 3.0.1 mixtureKEpsilon model is written with an incompressible form, which is contradictory with the description of the twoPhaseEulerFoam I use. Do anyone have an explanation ? Maybe it's written in an other way. Thank you for your help ! In version 2.3 it's like this (I suppose compressible form) Quote:
Whereas in version 3.0.1 it is (I suppose incompressible form) Code:
tmp<fvScalarMatrix> epsEqn ( fvm::ddt(epsilonm) + fvm::div(phim, epsilonm) - fvm::Sp(fvc::div(phim), epsilonm) - fvm::laplacian(DepsilonEff(nutm), epsilonm) == C1_*Gm*epsilonm/km - fvm::SuSp(((2.0/3.0)*C1_)*divUm, epsilonm) - fvm::Sp(C2_*epsilonm/km, epsilonm) + epsilonSource() ); |
Change turbulence model on engineFoam | Chapelle | OpenFOAM Running, Solving & CFD | 4 | January 26, 2018 11:14 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
change a variable in dissipation tem of turbulence model | behest | Fluent UDF and Scheme Programming | 0 | March 28, 2014 08:31 |
how to code Spalart-Allmaras turbulence model in unstructured mesh? | ervasph | Main CFD Forum | 0 | April 23, 2009 08:46 |
Turbulence model change | msha | OpenFOAM Running, Solving & CFD | 2 | September 28, 2007 03:08 |
