Adam Katz
Rep Power: 9 ![]() |
Hi all,
I want to simulate the flow of a heavy gas leak (transient, non reactive). For starters I want to use one of the buoyant solvers but I am not sure how to define the different species i.e. N2, SF6... Also, should I use: buoyantPimpleFoam, buoyantBoussinesqPimpleFoam or rhoReactingBuoyantFoam. Detailed examples much appreciated ![]() Thanks |
Adam Katz
I found a wonderful work:
Numerical modelling of gas dispersion using openFoam / (2016) by Savio Vianna In this work there is a detailed explanation how to use the rhoReactingBuoyantFoam solver using the combustion/reactingFoam tutorial as a base template. I'm going to try now! |
buoyant flow, buoyantpimplefoam, gas mixture |
Simulation of radial gas turbine, Inlet velocity components | dmaz | CFX | 17 | May 19, 2019 09:45 |
Gas simulation setup | anon_p | CONVERGE | 7 | April 30, 2019 11:49 |
Fluent Simulation of gas mixture in the pipe | free.man | FLUENT | 1 | November 26, 2016 00:59 |
Ideal gas v.s. Real gas for wing simulation | Anna Tian | Main CFD Forum | 1 | December 16, 2013 11:39 |
Tracer gas simulation with CFX4.3 | CFX 4.3 users | CFX | 3 | August 15, 2003 05:38 |
