"unknown psi type" error in reactingFoam
Old   July 24, 2017, 13:25
Default "unknown psi type" error in reactingFoam
Max
Speno93 is on a distinguished road
Hi all,
I am trying to simulate a gas mixing with air, for this I am using reactingFoam with chemistry and combustion turned off. However when I run the solver I get this error message.
--> FOAM FATAL ERROR:
Unknown psi type
chemistryType
    chemistrySolver EulerImplicit;
    chemistryThermo psi;
Valid psi types are:
chemistrySolver    chemistryThermo  transport   thermo       equationOfState           specie  energy
EulerImplicit      psi              const       hConst       incompressiblePerfectGas  specie  sensibleEnthalpy
EulerImplicit      psi              const       hConst       incompressiblePerfectGas  specie  sensibleInternalEnergy
EulerImplicit      psi              const       hConst       perfectGas                specie  sensibleEnthalpy
EulerImplicit      psi              const       hConst       perfectGas                specie  sensibleInternalEnergy
EulerImplicit      psi              polynomial  hPolynomial  icoPolynomial             specie  sensibleEnthalpy
EulerImplicit      psi              polynomial  hPolynomial  icoPolynomial             specie  sensibleInternalEnergy
EulerImplicit      psi              sutherland  janaf        incompressiblePerfectGas  specie  sensibleEnthalpy
EulerImplicit      psi              sutherland  janaf        incompressiblePerfectGas  specie  sensibleInternalEnergy
EulerImplicit      psi              sutherland  janaf        perfectGas                specie  sensibleEnthalpy
EulerImplicit      psi              sutherland  janaf        perfectGas                specie  sensibleInternalEnergy
noChemistrySolver  psi              const       hConst       incompressiblePerfectGas  specie  sensibleEnthalpy
noChemistrySolver  psi              const       hConst       incompressiblePerfectGas  specie  sensibleInternalEnergy
noChemistrySolver  psi              const       hConst       perfectGas                specie  sensibleEnthalpy
noChemistrySolver  psi              const       hConst       perfectGas                specie  sensibleInternalEnergy
noChemistrySolver  psi              polynomial  hPolynomial  icoPolynomial             specie  sensibleEnthalpy
noChemistrySolver  psi              polynomial  hPolynomial  icoPolynomial             specie  sensibleInternalEnergy
noChemistrySolver  psi              sutherland  janaf        incompressiblePerfectGas  specie  sensibleEnthalpy
noChemistrySolver  psi              sutherland  janaf        incompressiblePerfectGas  specie  sensibleInternalEnergy
noChemistrySolver  psi              sutherland  janaf        perfectGas                specie  sensibleEnthalpy
noChemistrySolver  psi              sutherland  janaf        perfectGas                specie  sensibleInternalEnergy
ode                psi              const       hConst       incompressiblePerfectGas  specie  sensibleEnthalpy
ode                psi              const       hConst       incompressiblePerfectGas  specie  sensibleInternalEnergy
ode                psi              const       hConst       perfectGas                specie  sensibleEnthalpy
ode                psi              const       hConst       perfectGas                specie  sensibleInternalEnergy
ode                psi              polynomial  hPolynomial  icoPolynomial             specie  sensibleEnthalpy
ode                psi              polynomial  hPolynomial  icoPolynomial             specie  sensibleInternalEnergy
ode                psi              sutherland  janaf        incompressiblePerfectGas  specie  sensibleEnthalpy
ode                psi              sutherland  janaf        incompressiblePerfectGas  specie  sensibleInternalEnergy
ode                psi              sutherland  janaf        perfectGas                specie  sensibleEnthalpy
ode                psi              sutherland  janaf        perfectGas                specie  sensibleInternalEnergy
    From function static Foam::autoPtr<T> Foam::basicChemistryModel::New(const Foam::fvMesh&, const Foam::word&) [with Thermo = Foam::psiChemistryModel]
    in file lnInclude/basicChemistryModelTemplates.C at line 117.
does anyone know why this keeps happening to me? Is it something to do with my thermophysical settings?
Speno93 is offline   Reply With Quote
Old   July 24, 2017, 16:18
Max
Well I figured out what the problem was, it turns out that my combination of thermo models is not supported in this combination of models, so I am going to attempt to compile a new version of the library which supports my combination of thermo models
Old   May 25, 2021, 10:15
HengLiu is on a distinguished road
Hi,sorry to bother.
I came up with the same problem when using reactingFoam.
Unknown basicChemistryModel type ode
All solver/methodcombinations for this thermodynamic model:
solver  method
All solver/method/reactionThermo/thermoPhysics combinations are:
solver             method    reactionThermo     transport   thermo       equationOfState           specie  energy
EulerImplicit      TDAC      psiReactionThermo  const       eConst       adiabaticPerfectFluid     specie  sensibleInternalEnergy
Could you give me some suggestions ?Thanks.
HengLiu is offline   Reply With Quote
How to modify psi value from the solver level (based on reactingFoam)? xinyu OpenFOAM Programming & Development 1 March 31, 2017 00:33
Different define of psi uesd in pEqn.H zqlhzx OpenFOAM Running, Solving & CFD 0 December 24, 2013 09:45
