Hanye Azimi
Rep Power: 9 ![]() |
Hi there
Is there "RBF motion solver" in new versions of OpenFOAM or I can find it only in OpenFOAM 1.5? Thanks in advance |
Retired Super Moderator
Bruno Santos
Rep Power: 128 ![]() ![]() ![]() ![]() ![]() ![]() |
Quick answer: I suspect you are referring to "OpenFOAM 1.5-dev", which I have explained on this thread: install , openFOAM 1.5 dev
As for RBF motion solver, it was continued in the subsequent versions after 1.5-dev, namely: OpenFOAM-Extend 1.6-ext, foam-extend 3.0 to and including 4.0. An alternative to RBF was implemented in OpenFOAM that is distributed at openfoam.org and openfoam.com, and it's named "Slerp": https://openfoam.org/release/2-3-0/mesh-motion/
openfoam 1.5, rbf motion solver |
Hybrid discretisation - blend factor | gcoopermax | CFX | 5 | September 23, 2016 08:05 |
Parallel implementation of RBF motion function | Cbose1991 | OpenFOAM Running, Solving & CFD | 0 | February 22, 2016 13:47 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
Motion diffusivity solver has problems with patches moving toward each other | bfa | OpenFOAM Running, Solving & CFD | 2 | July 8, 2009 21:35 |
