problems with reactingFOAM
Old   July 22, 2017, 13:33
Default problems with reactingFOAM
Chunkan Yu
antonyu1221 is on a distinguished road
Hello Foamers,
I want to compare the different chemistry-solvers in reactingFoam and chemFoam. Therefore, I use the reactingFoam to calculate the homogeneous ignition case. I set the volume as a constant. For the meshing, I set grid number to be 1 in all three directions. That means, I only have one cell. In such setting case, I have no convection, no diffusion, just only chemistry/reaction. However, as I did so, I found out that the mixture (H2/Air) under 1200 K, 1 bar will not be ignited within 0.001 s. However, under such conditions and using chemFoam, the mixture will be ignited very well. So does anyone know the reasons?
PS. I use the same ODE solvers, the same ddtSchema. All are the same.
thanks a lot in advance
antonyu1221 is offline   Reply With Quote
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
error with reactingFoam BakedAlmonds OpenFOAM Running, Solving & CFD 4 June 22, 2016 03:21
[mesh manipulation] Problems with rotational cyclic boundaries TReviol OpenFOAM Meshing & Mesh Conversion 8 July 11, 2014 04:45
[ICEM] Flow channel meshing problems StefanG ANSYS Meshing & Geometry 19 May 15, 2012 07:44
Help required to solve Hydraulic related problems aero CFX 0 October 30, 2006 12:00
