convergence problem with simpleFoam
Old   July 19, 2017, 19:07
Post convergence problem with simpleFoam
Ahmed Khattab's Avatar
ahmed
Ahmed Khattab is on a distinguished road
Hi All,
I am simulation a flow in a cylinder in order to get a velocity distribution at outlet, which i will use as inlet in another case.
in my current case, i'm using simleFoam, a wedge of a cylinder with 6mm radius, and 10 cm long. boundary conditions for pressure are zeroGradient every where except the outlet it was set to zero value. velocity boundary condition was set as fixedValue of zero at wall, zeroGradient at outlet, and flowRateInletVeloctiy at inlet. two sides were set as wedge in both blockMeshDict and boundary files. the axis of symmetry we set as empty in both blockMeshDict and boundary files. Re is 100.
tolerances for linear solver were set as 10^-9 for pressure and velocity, and zero for relative tolerances. also, residual was set to 10^-9.
GAMG was used for pressure with gaussSeidel smosther. smoothSolver was used for velociy with gaussSeidel smoother.
when i ran the solver for up to 10000 iteration, all fields initial residuals are fall below 10^-9 except Ux is stuck on 0.0035 initial residual. x is axis of symmetry and the direction of flow.
Ahmed Khattab is offline   Reply With Quote
Old   July 20, 2017, 11:23
Default repeating the simulation with icoFoam
ahmed
Hi there,
I have repeated the simulation using icoFoam solver, i have changed time step to get suitable Courant number, and it ran for 10 seconds.
at the end, i’ve got a parabolic profile of velocity at the outlet, the initial residuals of all fields fall below 10^-9, except of Ux again (it stuck on 0.016).
thanks.
convergence, pipe, simplefoam, wedge
simpleFoam - Convergence problem - Simple rectangular prism domain HakikiCanakkaleli OpenFOAM Running, Solving & CFD 5 May 9, 2013 05:59
Swirl flow convergence problem with simpleFoam iqbalsk8 OpenFOAM Running, Solving & CFD 7 November 28, 2012 01:54
simplefoam convergence problem Matt1986 OpenFOAM Running, Solving & CFD 6 October 16, 2012 09:32
Force can not converge colopolo CFX 13 October 4, 2011 23:03
Submerged fin, Convergence problem supermouniette FLUENT 10 July 6, 2009 11:47
