Problem with endTime by running OpenFOAM in parallel |
July 19, 2017, 09:34 |
Hey,
I have a simple simulation with a cylindrical geometry, for which I created the mesh in ICEM CFD. The top wall has a rotational movement and I am using simpleFoam, for this laminar flow of mine. Because the mesh has around 1,4M cells (all hexa) I am running parallel. I run the decomposePar - everything fine, than I run the mpirun. It is not important if I run on 2 or 3 cores, the result is the same: The run stops always after 6.784 s. It finishes normally, without any errors etc. I can run reconstructPar and postProcess everything normally, but still I need a longer simulation for my case. Aldo, I have in the controlDict specified the endTime: 50. Or 20 or 100. It is always the same. I was searching the forums and everything, but I didn't find a similar case. Has anyone dealt with this before? Ziga |
July 19, 2017, 12:39 |
Robert Castilla
Rep Power: 17 |
Hi, Ziga,
Probably it has stopped because it has reached the convergence criteria. Check the message at the end of the simulation log. Also check the system/fvSolution file for the convergence criteria. I hope it will help. Best regards Robert |
July 19, 2017, 13:21 |
aai... thanks, totally forgot that simpleFoam is a steadystate solver. That explains it all.
Sorry for bothering. I recently started with openFoam. Need to be more careful in the future. |
openfoam, parallel, problem, runtime |
problem of running parallel Fluent on linux cluster | ivanbuz | FLUENT | 15 | September 23, 2017 19:12 |
running OpenFoam in parallel | vishwa | OpenFOAM Running, Solving & CFD | 22 | August 2, 2015 08:53 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
OpenFOAM parallel running error in cluster | vishal_s | OpenFOAM Running, Solving & CFD | 5 | March 11, 2014 15:11 |
RSH problem for parallel running in CFX | Nicola | CFX | 5 | June 18, 2012 18:31 |
