Problem using the solidificationMeltingSource fvOption with compressibleInterFoam |
July 17, 2017, 06:07 |
Katana
Rep Power: 9 |
Hello everyone!
I am trying to simulate Stefan's problem with an compressible air gap on top. I included the fvOptions 'solidificationMeltingSource' for simulating the melting in the solid/liquid part which I set using . But for some reason, the entire domain gets filled with the solid/liquid part and there is no more air on top. I tried to implement it the way it was done here for Gallium melting: Tutorial/functional case for solidificationMeltingSource When I run the solver after I run setFields and topoSet, there is no more metal melting fraction (sMS1:alpha1) in the solved timesteps folders which I think indicates that the fvOptions is not active for some reason. I am new to OpenFOAM and I am not sure what I am doing wrong. Thanks Last edited by waterbender; July 18, 2017 at 06:09. Reason: updated attachment |
melting, openfoam, stefan problem |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
