scalarCodedSource and cellZones in OF 4.x
Old   July 13, 2017, 10:21
Default scalarCodedSource and cellZones in OF 4.x
Xavier Lamboley
tilasoldo is on a distinguished road
Hi everyone,
I am currently setting up a case with a time-varying volumetric energy source in OpenFOAM 4.x; I use scalarCodedSource fvOptions to achieve that, and after some research (in particular here…), I have managed to write this fvOptions file :
|  \\    /   O peration     | Version:  4.x                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      fvOptions;
heatSource
    type            scalarCodedSource;
    active          true;
    name            sourceTime;
    scalarCodedSourceCoeffs
        selectionMode   cellSet;
        cellSet         heaterCellSet;
        fields          (e);
        codeInclude
        codeCorrect
            Pout<< "**codeCorrect**" << endl;
        codeAddSup
            const Time& time = mesh().time();
            const scalarField& V = mesh_.V();
            scalarField& heSource = eqn.source();
            const labelList& cellIDs = cells();
            forAll(cellIDs, i)
                label cellI = cellIDs[i];
                heSource[cellI] -= 0.0001*sqr(time.value())*V[cellI];
        codeSetValue
            Pout<< "**codeSetValue**" << endl;
        // Dummy entry. Make dependent on above to trigger recompilation
        code
            $codeInclude
            $codeCorrect
            $codeAddSup
            $codeSetValue
    sourceTimeCoeffs
        $scalarCodedSourceCoeffs;
Source term indeed needs to be applied only on cellSet cells, as does
However, I get the following error :
.../fvOptions.heatSource.scalarCodedSourceCoeffs:45:40: error: use of undeclared identifier 'cells'
, even if I found this solution in the OpenFOAM issue tracker (!) for version 4.1. Am I doing this right? Do I miss an include?
I also tried to replace cells() by mesh_.cells(), which does not work any better since it returns a cellList instead of a labelList.
If anyone knows about this please share it with me
Regards,
X. Lamboley
tilasoldo is offline   Reply With Quote
