July 13, 2017, 08:43 |
endless loop
Alice
Rep Power: 9 |
I reluctantmeet a problem. When i calculate using interFoam at the terminal, it always calculate one time(time=0.19539). The result is that, Time = 0.19539 PIMPLE: iteration 1 smoothSolver: Solving for alpha.water, Initial residual = 8.34708e-07, Final residual = 5.17168e-11, No Iterations 1 Phase-1 volume fraction = 0.887425 Min(alpha.water) = 0 Max(alpha.water) = 1 MULES: Correcting alpha.water Phase-1 volume fraction = 0.887425 Min(alpha.water) = -9.95229e-30 Max(alpha.water) = 1 smoothSolver: Solving for alpha.water, Initial residual = 8.34204e-07, Final residual = 5.1608e-11, No Iterations 1 Phase-1 volume fraction = 0.887425 Min(alpha.water) = 0 Max(alpha.water) = 1 MULES: Correcting alpha.water Phase-1 volume fraction = 0.887425 Min(alpha.water) = -3.98091e-29 Max(alpha.water) = 1 smoothSolver: Solving for alpha.water, Initial residual = 8.33499e-07, Final residual = 5.14817e-11, No Iterations 1 Phase-1 volume fraction = 0.887425 Min(alpha.water) = 0 Max(alpha.water) = 1 MULES: Correcting alpha.water Phase-1 volume fraction = 0.887425 Min(alpha.water) = -3.98091e-29 Max(alpha.water) = 1 smoothSolver: Solving for alpha.water, Initial residual = 8.32854e-07, Final residual = 5.12874e-11, No Iterations 1 Phase-1 volume fraction = 0.887425 Min(alpha.water) = 0 Max(alpha.water) = 1 MULES: Correcting alpha.water Phase-1 volume fraction = 0.887425 Min(alpha.water) = -7.96183e-29 Max(alpha.water) = 1 DICPCG: Solving for p_rgh, Initial residual = 0.028875, Final residual = 0.00122469, No Iterations 2 time step continuity errors : sum local = 1.39085e-08, global = 2.26065e-13, cumulative = -3.06313e-08 DICPCG: Solving for p_rgh, Initial residual = 0.00947855, Final residual = 9.45228e-08, No Iterations 217 time step continuity errors : sum local = 1.07545e-12, global = 2.53134e-13, cumulative = -3.0631e-08 DILUPBiCG: Solving for epsilon, Initial residual = 0.00612527, Final residual = 1.66113e-11, No Iterations 3 DILUPBiCG: Solving for k, Initial residual = 5.04826e-12, Final residual = 5.04826e-12, No Iterations 0 ExecutionTime = 9204.45 s ClockTime = 9217 s Courant Number mean: 4.94712e-05 max: 0.496272 Interface Courant Number mean: 1.44084e-05 max: 0.171817 deltaT = 2.22645e-45 Time = 0.19539 PIMPLE: iteration 1 smoothSolver: Solving for alpha.water, Initial residual = 8.511e-07, Final residual = 5.40447e-11, No Iterations 1 Phase-1 volume fraction = 0.887425 Min(alpha.water) = 0 Max(alpha.water) = 1 MULES: Correcting alpha.water Phase-1 volume fraction = 0.887425 Min(alpha.water) = -6.2669e-31 Max(alpha.water) = 1 smoothSolver: Solving for alpha.water, Initial residual = 8.50594e-07, Final residual = 5.39369e-11, No Iterations 1 Phase-1 volume fraction = 0.887425 Min(alpha.water) = 0 Max(alpha.water) = 1 MULES: Correcting alpha.water Phase-1 volume fraction = 0.887425 Min(alpha.water) = -8.02164e-29 Max(alpha.water) = 1 smoothSolver: Solving for alpha.water, Initial residual = 8.49823e-07, Final residual = 5.38165e-11, No Iterations 1 Phase-1 volume fraction = 0.887425 Min(alpha.water) = 0 Max(alpha.water) = 1 MULES: Correcting alpha.water Phase-1 volume fraction = 0.887425 Min(alpha.water) = -2.44801e-33 Max(alpha.water) = 1 smoothSolver: Solving for alpha.water, Initial residual = 8.49126e-07, Final residual = 5.36118e-11, No Iterations 1 Phase-1 volume fraction = 0.887425 Min(alpha.water) = 0 Max(alpha.water) = 1 MULES: Correcting alpha.water Phase-1 volume fraction = 0.887425 Min(alpha.water) = -2.00541e-29 Max(alpha.water) = 1 DICPCG: Solving for p_rgh, Initial residual = 0.0309779, Final residual = 0.0012495, No Iterations 2 time step continuity errors : sum local = 1.46089e-08, global = 3.53085e-13, cumulative = -3.06307e-08 DICPCG: Solving for p_rgh, Initial residual = 0.00900407, Final residual = 7.30247e-08, No Iterations 265 time step continuity errors : sum local = 8.53157e-13, global = 8.01513e-16, cumulative = -3.06307e-08 DILUPBiCG: Solving for epsilon, Initial residual = 0.0064206, Final residual = 2.15077e-11, No Iterations 3 DILUPBiCG: Solving for k, Initial residual = 5.19511e-12, Final residual = 5.19511e-12, No Iterations 0 ExecutionTime = 9206.18 s ClockTime = 9218 s Courant Number mean: 5.07062e-05 max: 0.49549 Interface Courant Number mean: 1.47119e-05 max: 0.185369 deltaT = 2.24672e-45 Time = 0.19539 It must get into endless loop. I don't kwon how to modify. And I don't know what should post for you easy to understand. If you need something to know, just reply. Thank you! |
July 13, 2017, 09:42 |
#2 | |
Kevin van As
Rep Power: 21 |
deltaT = 2.24672e-45 Time = 0.19539 Your timestep is way too small, yet your Courant number is 0.5. In other words, your velocity is very large (for example ). Your simulation has diverged, yet adaptive timestepping hides this by simply making deltaT very small. Without further information about your case, no one can help you. However, it seems like an awfully bad idea to use only two pressure loops, with relTol=0.1. No way your simulation will converge then. In your case, this probably causes your divergence. Try relTol=0.01 and nCorrectors=10. |
July 13, 2017, 22:21 |
Alice
Rep Power: 9 |
Thanks for your reply. I have tried relTol=0.01 and nCorrectors=10. But it has no change, and it calculates very very slowly. In my case, there are two phase flow(gas and water) in the circular tube(1m for length, 0.025m for radius), and grid size is 2.5 millimeters. This case has sucessfully calculated 15 meters long circular tube. I just changed the geometry model. I don't know where is going wrong. Now I post the fvsolution here. [CODE] solvers { "alpha.water.*" { nAlphaCorr 1; nAlphaSubCycles 4; cAlpha 2; MULESCorr yes; nLimiterIter 3; solver smoothSolver; smoother symGaussSeidel; tolerance 1e-8; relTol 0.01; } pcorr { solver PCG; preconditioner DIC; tolerance 1e-10; relTol 0.01; } p_rgh { solver PCG; preconditioner DIC; tolerance 1e-07; relTol 0.01; } p_rghFinal { $p_rgh; relTol 0.01; } "(U|k|epsilon).*" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-06; relTol 0.01; } "(U|k|epsilon)Final.*" { solver PBiCG; preconditioner DILU; tolerance 1e-08; relTol 0.01; } } PIMPLE { momentumPredictor no; nOuterCorrectors 1; nCorrectors 10; nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; nAlphaCorr 1; nAlphaSubCycles 4; cAlpha 2; } relaxationFactors { equations { ".*" 1; } } The controlDict is that, [CODE] application interFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 5; deltaT 0.001; writeControl adjustableRunTime; writeInterval 0.05; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression compressed; timeFormat general; timePrecision 6; runTimeModifiable yes; adjustTimeStep yes; maxCo 0.5; maxAlphaCo 0.5; maxDeltaT 1; } |
July 14, 2017, 05:27 |
#4 | ||
Kevin van As
Rep Power: 21 |
Please note that you should close code-tags with "[/code]".
Don't compare the speed of the simulation with your previous simulation, as your previous run was fast only because it was calculating nonsense (you didn't give it time to converge). Quote:
p_rgh { solver GAMG; //PCG; //GAMG; //preconditioner DIC; // PCG needs preconditioner, GAMG does not tolerance 1e-07; relTol 0.01; smoother symGaussSeidel; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration yes; nCellsInCoarsestLevel 1000; // should be ~sqrt(Ncells) agglomerator faceAreaPair; //mergeLevels 1; } p_rghFinal { $p_rgh; relTol 0; } The lines I marked blue are wrong. You should never have a relTol for the Final iteration, otherwise the case will (again) not converge properly. That's why I set relTol=0 in my snippet above. Quote:
Also, is the mesh identical in shape / number of cells / etc.? Perhaps your turbulence model requires adaptation as well (I know too little about turbulence modelling to say anything sensible on that matter)? |
July 14, 2017, 23:25 |
#5 | |
Alice
Rep Power: 9 |
Yesterday I tried for a long time. I change a turbulence model, and it works. Thank you for your help! Best |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 03:36 |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 12:04 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 03:09 |
[CAD formats] my stl surface is seen as just a line | rcastilla | OpenFOAM Meshing & Mesh Conversion | 2 | January 6, 2010 02:30 |
NACA0012 geometry/design software needed | Franny | Main CFD Forum | 13 | July 7, 2007 16:57 |
