correct finite volume schemes
Old   July 6, 2017, 16:59
Default correct finite volume schemes
Bobby
babakflame is on a distinguished road
Dear Fellows
I am solving a 1D case with two transport equations for ions and a Poisson equation for additional parameter relating concentrations to each other. The simulation is stable and my initial residual keeps reducing.
However, an artificial oscillations occurs with my concentrations. I mean although the values seem fine , they alternatively flip sign. This is a sample of my cPlus concentration file written during simulation (first lines of concentration file)
internalField   nonuniform List<scalar>
20000
-42240801498
-42240801498
-42240801497.7
-42240801497.9
-42240801497.9
-42240801497.9
-42240801498.1
-42240801498.1
-42240801498.1
-42240801498.1
6571685.77352
6571685.77353
6571685.77345
6571685.77353
6571685.7735
6571685.77351
6571685.77359
6571685.7736
6571685.77359
6571685.77358
-676.881846854
-676.881846855
-676.881846844
-676.881846857
-676.881846851
-676.881846853
-676.881846865
-676.881846866
-676.881846864
-676.881846863
I want to underline that values are sensible for me. However, not the sign change. I think sth is missing in my schemes. This is my fvSchems file:
ddtSchemes
    default         Euler;
gradSchemes
    default         leastSquares;
divSchemes
    default          Gauss linear;
    div(rho*phi,U)   Gauss upwind;
    div(phi,cMinus)    Gauss upwind;
    div(phi,cPlus)    Gauss upwind;
    div(phi,alpha)   Gauss vanLeer;
    div(phirb,alpha) Gauss interfaceCompression;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p_rgh;
    pcorr;
    alpha;
    cMinus;
    cPlus;
Any hint fellows? My concentration variables are cPlus and cMinus. There is no velocity in this simulation. Just Diffusion and time derivative plus electro-migrative terms.
So, I have to come up with other schemes for gradient and interpolation schemes.
I tried to employ NVD schemes for interpolationSchemes. I mean changing fvSchemes to:
ddtSchemes
    default         backward;
gradSchemes
divSchemes
laplacianSchemes
    default         Gauss linear limited 1.0;
    default         SFCD;
snGradSchemes
    default         limited 0.5;
fluxRequired
    default         no;
    p_rgh;
    pcorr;
    alpha;
    cMinus;
    cPlus;
--> FOAM FATAL IO ERROR:
attempt to read beyond EOF
file: /home/babak/Desktop/NoFlow/1D/Steric/a_3nm/Ue_500/Ue_100/system/fvSchemes::interpolationSchemes::default at line 45.
    From function ITstream::read(token&)
    in file db/IOstreams/Tstreams/ITstream.C at line 83.
FOAM exiting
Can anybody hint me how can I employ NVD schemes correctly or how can I remove this artificial oscillation?
Regards
babakflame is offline   Reply With Quote
Old   July 7, 2017, 07:50
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
(N|T)VD schemes need flux for limiters. In case of 'div(phi,?)' schemes can find flux, in other cases, they can not. So to use SFCD for interpolation (have doubts it helps with oscillations) you have to put 'SFCD phi'. Error message is awful but it is a result of "universality".
alexeym is offline   Reply With Quote
Old   July 7, 2017, 17:55
Bobby
Dear Alexey
Many thanks for your reply. Unfortunately, I am solving the equations without convective term.
My equations are as follows:
 surfaceScalarField cPlusFlux  = -DeKbT*fvc::interpolate(cPlus)*mesh.magSf()*fvc::snGrad(Ue);
        surfaceScalarField cMinusFlux =  DeKbT*fvc::interpolate(cMinus)*mesh.magSf()*fvc::snGrad(Ue);
 //           surfaceScalarField cPlusFlux  = -fvc::interpolate(sgm)*mesh.magSf()*fvc::snGrad(Ue);
           surfaceScalarField cPlusArtDiff  =
        -acubkappa*fvc::interpolate(cPlus)*mesh.magSf()*fvc::snGrad(cAgg)/(1-acub*fvc::interpolate(cPlus)-acub*fvc::interpolate(cMinus));
const double convergenceTolerance = 1e-02;
double initialResidualA = 0.0;
double initialResidualB = 0.0;
double initialResidualC = 0.0;
double initialResidual = 0.0;
do {
    cMinus.storePrevIter();
    cPlus.storePrevIter();
    Ue.storePrevIter();
       surfaceScalarField cMinusArtDiff  =
        -acubkappa*fvc::interpolate(cMinus)*mesh.magSf()*fvc::snGrad(cAgg)/(1-acub*fvc::interpolate(cMinus)-acub*fvc::interpolate(cPlus));
            fvScalarMatrix cPlusEqn
                fvm::ddt(cPlus)
              + fvc::div(cPlusFlux)
          - fvc::div(cPlusArtDiff)
           - fvm::laplacian(kappa, cPlus)
            initialResidualA = cPlusEqn.solve().initialResidual();
            fvScalarMatrix cMinusEqn
                fvm::ddt(cMinus)
              + fvc::div(cMinusFlux)
              - fvc::div(cMinusArtDiff)
           - fvm::laplacian(kappa, cMinus)
           initialResidualB = cMinusEqn.solve().initialResidual();
           initialResidual = (initialResidualB > initialResidualA) ? initialResidualB : initialResidualA;
        cAgg = (cPlus + cMinus);
        rhoE = (cPlus - cMinus) * elem;
              // solve
            fvScalarMatrix UeEqn
                fvm::laplacian(eps,Ue) == -rhoE
       initialResidualC = UeEqn.solve().initialResidual();
          initialResidual = (initialResidualC > initialResidual) ? initialResidualC : initialResidual;
} while (initialResidual > convergenceTolerance);
//          Convective = fvm::div(phi, rhoE);
           E = -fvc::grad(Ue);
    volVectorField gradUe = fvc::grad(Ue);
        gradUex = gradUe.component(vector::X);
        gradUey = gradUe.component(vector::Y);
As you can see, there is no convective term (phi in OpenFOAM notation). I tried NVD schemes through the following updated fvSchemes file:
ddtSchemes
    default         backward;
gradSchemes
divSchemes
laplacianSchemes
    default         linear;
cPlusFlux    Gamma 0.5;
cMinusFlux    Gamma 0.5;
cMinusArtDiff    Gamma 0.5;
cPlusArtDiff    Gamma 0.5;
snGradSchemes
fluxRequired
    default         no;
    p_rgh;
    pcorr;
    alpha;
    cMinus;
    cPlus;
However, I still face the problem of artificial oscillations in concentration values. I mean flipping signs.
Regards
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
The fundamental difference between Finite Difference and Finite Volume Methods vikramaditya91 Main CFD Forum 3 January 14, 2016 05:13
Control Volume Finite Element Method gerardosrez Main CFD Forum 0 March 16, 2011 15:49
Control Volume , Finite Volume, Finite Control Volume, Finite Element Method technocrat.prakash Main CFD Forum 1 April 24, 2010 20:24
