High Reynold's Number flow through diverging channel |
July 5, 2017, 07:06 |
Arka Raha
I have been trying to simulate flow through a diverging channel with angle of divergence 20 degrees in OpenFoam. The boundary conditions worked well for lesser Reynold's Number but failed when the Reynold's number were increased to 1000. The error being shown is nan (not a number). The boundary conditions were also working fine when I worked with angle of divergence 10 degrees in case of Reynold's number 1000.
The boundary conditions which I had initially provided are: Inlet:- U- fixedValue p- zeroGradient Outlet:- U-zeroGradient p- fixedValue (zero) Can anyone suggest what should be the ideal boundary conditions to run the simulations? Last edited by arka14; July 7, 2017 at 04:42. |
channel flow, diverging |
High reynolds number model and a low reynolds number model | Ieg1995 | Main CFD Forum | 3 | June 18, 2017 13:18 |
Turbulence model for low Reynolds number flow? | Nokadu | Main CFD Forum | 3 | May 26, 2013 11:42 |
parallel code | samiam1000 | SU2 | 3 | March 25, 2013 04:55 |
how to calculate CFL number in 3D convection-diffusion channel flow | dryhill | Main CFD Forum | 0 | June 24, 2009 03:33 |
Difficulties in solving a high Reynolds number Flow? | wowakai | Main CFD Forum | 10 | December 29, 1998 13:46 |
