transform incompressible case in compressible case |
July 5, 2017, 05:17 |
Rep Power: 9 |
hello,
I made an incompressible case for external aerodynamic with pimpleDyMFoam with an moving mesh. Now I want to work on this case but for compressible flow. I copied this case and I changed the solver to rhoPimpleDyMFoam and I added thermophysicalproperties file in constant folder but it doesn't works. Is my procedure good? If it isn't good, can you explain me what I have to do? The mesh have to be specific for a subsonic case? thanks in advance |
October 23, 2020, 17:34 |
Ilteber Ozdemir
Check the following thread:
quick way to change from incompressible to compressible? |
compressible, external aerdynamics, moving mesh, pimpledymfoam, rhopimpledymfoam |
Modify compressible solver to incompressible | mingzhao | OpenFOAM Running, Solving & CFD | 0 | September 18, 2015 12:50 |
Different surface flow values - Incompressible case | kornickel | OpenFOAM Post-Processing | 2 | October 21, 2013 04:47 |
Difference between Compressible CFD solver and Incompressible CFD solver | arijith | Main CFD Forum | 6 | September 23, 2012 19:23 |
compressible and incompressible flow | chinababu | FLUENT | 4 | November 13, 2008 05:56 |
Compressible vs. incompressible NS at high Temperatures | Jean Lacroix | Main CFD Forum | 1 | December 24, 1999 06:21 |
