July 4, 2017, 23:31 |
BluntCone Case Fatal Error
Hi to everyone, I'm new using OpenFOAM I'm trying to run a tutorial I found on the internet, which is a variation of the motorBike Case, but in the final part I have a problem to execute simpleFoam, I left you below the links to the tutorials
https://ffrufffruf.wordpress.com/2013/02/21/first-openfoam-tutorial/ https://ffrufffruf.wordpress.com/2013/02/26/first-openfoam-tutorial-part-2/ https://ffrufffruf.wordpress.com/2013/03/06/first-openfoam-tutorial-part-3/ can you help me try to solve this problem I would really appreciate it /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 4.1 Exec : simpleFoam Date : Jul 05 2017 Time : 07:27:40 Host : "andres-Lenovo-G40-45" PID : 3707 Case : /home/andres/OpenFOAM/OpenFOAM-dev/tutorials/incompressible/simpleFoam/bluntCone nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 3 SIMPLE: no convergence criteria found. Calculations will run for 497 steps. Reading field p --> FOAM FATAL IO ERROR: Cannot open include file "/home/andres/OpenFOAM/OpenFOAM-dev/tutorials/incompressible/simpleFoam/bluntCone/3/include/initialConditions" while reading dictionary "/home/andres/OpenFOAM/OpenFOAM-dev/tutorials/incompressible/simpleFoam/bluntCone/3/p" file: /home/andres/OpenFOAM/OpenFOAM-dev/tutorials/incompressible/simpleFoam/bluntCone/3/p at line 17. From function static bool Foam::functionEntries::includeEntry::execute(Foam: :dictionary&, Foam::Istream&) in file db/dictionary/functionEntries/includeEntry/includeEntry.C at line 146. FOAM exiting Last edited by AndresRay; July 5, 2017 at 11:52. |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 01:21 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 12:39 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 10:31 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 10:30 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 11:23 |
