nsreddy
Rep Power: 15 ![]() |
I wanted to simulate the fluid flow and heat transfer through double pipe heat exchanger. Hot water is flowing through the inner tube and cold water flowing through annulus.
Bc are as follows Hot water inlet temp is 65 C and cold inlet temp is 30 C , mc is 0.1 kg per s and mh is 0.1 kg per sec . Pressure outlet for both the fluids. Please suggest me the appropriate solver for the above problem. Regards NSReddy |
Agustín Villa
Hello
what about the pipe? Do you need conjugate heat transfer too? Take a look into https://github.com/OpenFOAM/OpenFOAM...s/heatTransfer The solver you will use depends on what you are going to simulate |
nsreddy
thanks for the reply
how the algorithm changes if i take temp within the solid and fluid if i take temp variation only in fluids. any references on conjugate heat transfer regards |
Agustín Villa
Hello
if you consider conjugate heat flux, of course you have to solve the heat conduction inside the solid, and between solid and fluid. In the other case it is just the fluid equations. Take a look into the solvers I specified to see the differences in the algorithm. |
nsreddy
thanks a lot i will go through it
nsreddy
is there any similar tutorial on double pipe heat exchanger
thanks and regards |
[Other] OpenFOAM Installation for navalFoam | sachinlb | OpenFOAM Community Contributions | 22 | July 28, 2017 05:26 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
Solver selection for transonic compressor stage in Foam-extend-3.0 | dowlee | OpenFOAM Running, Solving & CFD | 1 | April 16, 2015 13:33 |
Problem in3D model processing | mebinitap | OpenFOAM | 2 | December 12, 2014 04:40 |
Setting a B.C using UserFortran in 4.3 | tokai | CFX | 10 | July 17, 2001 16:25 |
