Miguel García Casas
Rep Power: 9 ![]() |
Hello everyone,
I developed a testing case in 2D with an stationary domain and a moving one (with a constant angular velocity). I used OpenFOAM 4.1 with the cyclicAMI boundary and pimpleDyMFoam. It works very well with a laminar simulation. Now I'm trying to import this case into foam-extend, so I made some modifications to use cyclicGGI and it almost works. I have two problems:
The case is inside the dropbox link, if someone may check it. I will be so glad. Best Regards! |
cyclic boundary, foam-extend-4.0, movemesh, pimpledymfoam |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 04:38 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
