OpenFoam kOmega printStack Error (Help)
Old   June 21, 2017, 14:54
Default OpenFoam kOmega printStack Error (Help)
George
last_jedi is on a distinguished road
Hi guys, i am quite new in OpenFoam. I have been trying to setup a RANS k-Omega simulation in OpenFoam. My mesh is exported from Pointwise in OpenFoam format and is a realistic car model created with T-Rex tool.
I have followed some tutorials in order to set-up my case in OpenFoam but i get the following Error. Any help pls..???
kOmegaSSTCoeffs
alphaK1 0.85;
alphaK2 1;
alphaOmega1 0.5;
alphaOmega2 0.856;
gamma1 0.555556;
gamma2 0.44;
beta1 0.075;
beta2 0.0828;
betaStar 0.09;
a1 0.31;
b1 1;
c1 10;
F3 false;
No MRF models present
No finite volume options present
Starting time loop
Time = 0.001
smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.00741547, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver: Solving for Uz, Initial residual = 0, Final residual = 0, No Iterations 0
#0 Foam::error:rintStack(Foam::Ostream&) in "/apps/OpenFOAM+/OpenFOAM-v1612+/platforms/linux64IccDPInt32Opt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/apps/OpenFOAM+/OpenFOAM-v1612+/platforms/linux64IccDPInt32Opt/lib/libOpenFOAM.so"
#2 ? in "/lib64/libc.so.6"
#3 double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) in "/apps/OpenFOAM+/OpenFOAM-v1612+/platforms/linux64IccDPInt32Opt/lib/libOpenFOAM.so"
#4 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/apps/OpenFOAM+/OpenFOAM-v1612+/platforms/linux64IccDPInt32Opt/lib/libOpenFOAM.so"
#5 Foam::GAMGSolver::solveCoarsestLevel(Foam::Field<d ouble>&, Foam::Field<double> const&) const in "/apps/OpenFOAM+/OpenFOAM-v1612+/platforms/linux64IccDPInt32Opt/lib/libOpenFOAM.so"
#6 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/apps/OpenFOAM+/OpenFOAM-v1612+/platforms/linux64IccDPInt32Opt/lib/libOpenFOAM.so"
#7 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/apps/OpenFOAM+/OpenFOAM-v1612+/platforms/linux64IccDPInt32Opt/lib/libOpenFOAM.so"
#8 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) in "/apps/OpenFOAM+/OpenFOAM-v1612+/platforms/linux64IccDPInt32Opt/lib/libfiniteVolume.so"
#9 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/apps/OpenFOAM+/OpenFOAM-v1612+/platforms/linux64IccDPInt32Opt/bin/simpleFoam"
#10 ? in "/apps/OpenFOAM+/OpenFOAM-v1612+/platforms/linux64IccDPInt32Opt/bin/simpleFoam"
#11 __libc_start_main in "/lib64/libc.so.6"
#12 ? in "/apps/OpenFOAM+/OpenFOAM-v1612+/platforms/linux64IccDPInt32Opt/bin/simpleFoam"
Floating point exception (core dumped)
s258761@ssw7228f-li [112] 06:41 PM [motorbike2]
last_jedi is offline   Reply With Quote
Old   June 22, 2017, 04:47
Alex
Kina is on a distinguished road
please post fvSolution, fvSchemes and controlDict as code.
Why is your timestep 0.001 (looks transient) but your solver seems to be simpleFoam (steady)?
cheers
alex
Kina is offline   Reply With Quote
Old   June 22, 2017, 05:55
BlnPhoenix is on a distinguished road
Have you tried "laminar" first? Is your case running succesfully with laminar?
From the error code alone it's not clear where the error sits in your setup.
BlnPhoenix is offline   Reply With Quote
Old   June 25, 2017, 15:20
George
cheers
alex
My timestep was initially 1, but i tried a smaller timestep to see if it could give any better results. My fvSolution, fvSchemes and controlDict are the following:
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSolution;
solvers
p
solver GAMG;
smoother GaussSeidel;
tolerance 1e-7;
relTol 0.01;
Phi
$p;
U
solver smoothSolver;
tolerance 1e-8;
relTol 0.1;
nSweeps 1;
k
tolerance 1e-8;
relTol 0.1;
nSweeps 1;
omega
tolerance 1e-8;
relTol 0.1;
nSweeps 1;
SIMPLE
nNonOrthogonalCorrectors 0;
consistent yes;
residualControl
p 0.001;
U 0.001;
k 0.001;
omega 0.001;
potentialFlow
nNonOrthogonalCorrectors 10;
relaxationFactors
equations
U 0.3;
k 0.3;
omega 0.3;
cache
grad(U);
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSchemes;
ddtSchemes
default steadyState;
gradSchemes
default cellLimited leastSquares 1.0;
divSchemes
default none;
div(phi,U) bounded Gauss linearUpwindV grad(U);
div(phi,k) bounded Gauss upwind;
div(phi,omega) bounded Gauss upwind;
div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default limited corrected 0.5;
wallDist
method meshWave;
FoamFile
version 2.0;
format ascii;
class dictionary;
object controlDict;
application simpleFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 100;
deltaT 1;
writeControl timeStep;
writeInterval 100;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression uncompressed;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
Old   June 25, 2017, 16:21
Alex
Why are you using such fancy schemes?
for grad, I would start with "default linear"
for snGrad, I would stay with "default corrected"
for div(phi,U), I would start with "bounded Gauss upwind" and then change it to "bounded Gauss linear" later.
From my experience, the rather fancy schemes in of really have to fit the problem. Otherwise, you are just making it worse.
One more thing: your smoothSolver says, it's solving only in X-direction. For y and z it shows 0 iterations. What's your checkMesh?
Timestep for simpleFoam is irrelevant since it doesn't have a time scheme. So 1 is ok and reasonable
Cheers
Alex
Old   June 26, 2017, 07:47
George
Cheers
Alex
Thank you for your advises. In the beginning my mesh check failed. But now its okk, after some changes in my initial mesh. Even though i followed your proposals i still get the same error. The only difference now is that in X-Direction it solves for 1000 it. and in y and z only 1 i.
Old   June 26, 2017, 10:34
Alex
Can you post the checkMesh output? Also, I would go for maxIter 100 on the velocity solver.
Old   June 26, 2017, 13:04
George
Where can i change max. iterations for velocity solver? My checkMesh screenshot is the following:
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
faces: 17960892
internal faces: 17441560
cells: 8850613
faces per cell: 4
boundary patches: 7
point zones: 0
face zones: 0
cell zones: 0
Overall number of cells of each type:
hexahedra: 0
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 8850613
polyhedra: 0
Checking topology...
Boundary definition OK.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
Patch Faces Points Surface topology
car 436892 218448 ok (closed singly connected)
ceiling 5908 3043 ok (non-closed singly connected)
floor 71486 35832 ok (non-closed singly connected)
inlet_main 1076 586 ok (non-closed singly connected)
inlet_secondary 1452 788 ok (non-closed singly connected)
outflow_main 1072 584 ok (non-closed singly connected)
outflow_secondary 1446 785 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-13.839 -18.452 0) (36.904 18.452 9.226)
Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
Mesh has 3 solution (non-empty) directions (1 1 1)
Boundary openness (2.18482e-18 -3.17211e-16 1.7067e-15) OK.
Max cell openness = 3.12272e-16 OK.
Max aspect ratio = 11.4276 OK.
Minimum face area = 3.29743e-07. Maximum face area = 1.39245. Face area magnitudes OK.
Min volume = 8.22926e-11. Max volume = 0.505525. Total volume = 17269.7. Cell volumes OK.
Mesh non-orthogonality Max: 61.7408 average: 19.6088
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 0.958172 OK.
Coupled point location match (average 0) OK.
Mesh OK.
End
Old   June 27, 2017, 03:40
Alex
In fvSolution, put for p:
solver GAMG;
tolerance 1e-7;
relTol 0.01;
maxIter 100;
The rest looks fine. Of course, your skewness and non-orthogonality are pretty high but that should not be the problem.
My final guess is that you could have messed something up with the boundary conditions. Can you post these?
Old   June 27, 2017, 08:20
George
I tried what you proposed for "p" in fvSolution but unfortunately doesn't change anything. My boundary file can be seen below. "Inlet secondary" and "outflow secondary" are just side walls of the outer box domain which i will use later in order to implement sidewind velocity. So at the moment i am using them as side walls and declared them as symmetry planes.
FoamFile
version 2.0;
format ascii;
class polyBoundaryMesh;
location "constant/polyMesh";
object boundary;
7
car
type wall;
nFaces 436892;
startFace 17441560;
ceiling
type symmetryPlane;
nFaces 5908;
startFace 17878452;
floor
type wall;
nFaces 71486;
startFace 17884360;
inlet_main
type patch;
nFaces 1076;
startFace 17955846;
inlet_secondary
type symmetryPlane;
nFaces 1452;
startFace 17956922;
outflow_main
type patch;
nFaces 1072;
startFace 17958374;
outflow_secondary
type symmetryPlane;
nFaces 1446;
startFace 17959446;
Old   June 27, 2017, 11:54
Alex
The maxIter stuff doesn't solve a problem. It's not supposed to. I'm just saying that if your solver takes more than 100 iterations to solve the matrix, there's something wrong with your setup.
I didn't mean the boundary file, but the boundary conditions:
0/p
0/U
0/k
0/omega
Old   June 28, 2017, 08:14
George
My boundary condition files are the following:
U:
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
flowVelocity ( 16 0 0 );
pressure 0;
turbulentKE 0.1536;
turbulentOmega 0.155;
dimensions [ 0 1 -1 0 0 0 0 ];
internalField uniform ( 16 0 0 );
boundaryField
outflow_main
type inletOutlet;
inletValue uniform ( 0 0 0 );
value uniform ( 16 0 0 );
floor
type fixedValue;
value uniform (16 0 0);
car
type fixedValue;
value uniform (0 0 0);
ceiling
type symmetryPlane;
outflow_secondary
type symmetryPlane;
inlet_secondary
type symmetryPlane;
inlet_main
type fixedValue;
P:
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet_main
type zeroGradient;
outflow_main
type fixedValue;
value uniform 0;
floor
type zeroGradient;
car
type zeroGradient;
inlet_secondary
type symmetryPlane;
outflow_secondary
type symmetryPlane;
ceiling
type symmetryPlane;
K:
FoamFile
version 2.0;
format ascii;
object k;
internalField uniform 0.1536;
boundaryField
outflow_main
type inletOutlet;
inletValue uniform 0.1536;
value uniform 0.1536;
floor
type kqRWallFunction;
car
outflow_secondary
type symmetryPlane;
inlet_secondary
type symmetryPlane;
ceiling
type symmetryPlane;
inlet_main
type fixedValue;
omega:
FoamFile
version 2.0;
format ascii;
object omega;
dimensions [0 0 -1 0 0 0 0];
internalField uniform 0.155;
boundaryField
outflow_main
type inletOutlet;
inletValue uniform 0.155;
value uniform 0.155;
floor
type omegaWallFunction;
car
ceiling
type symmetryPlane;
outflow_secondary
type symmetryPlane;
inlet_secondary
type symmetryPlane;
inlet_main
type fixedValue;
Old   June 28, 2017, 08:38
Alex
Without seeing a picture of your setup, I'd suggest the following:
Originally Posted by last_jedi View Post
U:
FoamFile
version 2.0;
format ascii;
location "0";
object U;
pressure 0;
turbulentKE 0.1536;
boundaryField
outflow_main
type zeroGradient;
floor
type fixedValue;
car
type fixedValue;
ceiling
type symmetryPlane;
outflow_secondary
type symmetryPlane;
inlet_secondary
type symmetryPlane;
inlet_main
type fixedValue;
P:
FoamFile
version 2.0;
format ascii;
object p;
boundaryField
inlet_main
type zeroGradient;
outflow_main
type fixedValue;
value uniform 0;
floor
type zeroGradient;
car
type zeroGradient;
inlet_secondary
type symmetryPlane;
outflow_secondary
type symmetryPlane;
ceiling
type symmetryPlane;
K:
FoamFile
version 2.0;
format ascii;
object k;
boundaryField
outflow_main
type zeroGradient;
floor
value uniform 1e-8;
car
value uniform 1e-8;
outflow_secondary
type symmetryPlane;
inlet_secondary
type symmetryPlane;
ceiling
type symmetryPlane;
inlet_main
type fixedValue;
omega:
FoamFile
version 2.0;
format ascii;
object omega;
boundaryField
outflow_main
type zeroGradient;
floor
value uniform 1e7;
car
value uniform 1e7;
ceiling
type symmetryPlane;
outflow_secondary
type symmetryPlane;
inlet_secondary
type symmetryPlane;
inlet_main
type fixedValue;
In summary: your BCs don't make much sense
- You are specifying pressure and velocity outlet
- you are specifying k and omega at outlet
- you are fixing a velocity on a wall patch
If you want the floor wall to be no slip which is not physical, then set the velocity to zerogradient. But never fix a velocity on a wall patch other than (0 0 0), that will blow up every case.
I have updated the new BCs in the Quote.
One more thing: why are you setting the ceiling to symmetry? I'd go for a patch or wall with zeroGradient BCs.
Cheers
Alex
Old   June 28, 2017, 11:43
George
First of all, thank you Alex so much for your immediate responses. I tried your updated modified files but still the problem seems to insist. I forgot to upload the nut file, maybe this needs some modification too. Finally as far as the ceiling concerns i am using symmetry plane in order to relief a bit the simulation load.
nut:
FoamFile
version 2.0;
format ascii;
location "0";
object nut;
dimensions [0 2 -1 0 0 0 0];
boundaryField
inlet_secondary
type symmetryPlane;
inlet_main
type calculated;
value uniform 0;
outflow_main
type zeroGradient;
floor
{ type nutkWallFunction;
value uniform 0;
ceiling
type symmetryPlane;
car
value uniform 0;
outflow_secondary
type symmetryPlane;
Old   June 28, 2017, 11:55
Alex
Should be ok with the nut. Depending if you're using LowRe SST, you can set the nut for wall to type calculated; value 0;
In case you are allowed to share the case files, I'd be willing to have a look into it since we have captured most of the sources for those errors so far. As I don't know what your mesh or setup looks like, I can only make certain guesses.
You can also upload the case and send a private message.
Cheers,
Alex
Old   June 28, 2017, 12:01
hokhay is on a distinguished road
Have you tried altering relTol and residualControl value. I usually use 0.01 for relTol and 1e-5 for residuals. Use potentialFoam to initialize the solution and check if something wrong with the boundary conditions.
Sent from my LG-H818 using CFD Online Forum mobile app
hokhay is offline   Reply With Quote
Old   June 28, 2017, 12:17
Alex
One more thing you can try to see if the solver at least takes more iterations to blow up:
in the fvSolution, change the underrelaxation to:
relaxationFactors
   fields
     p     0.3;
       equations
             U                  0.3;
             k                  0.3;
             omega               0.3;
Just to check if it's the initially large change in pressure causing the solver to crash.
error, komega sst model, openfoam, printstack
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
OpenFOAM Foundation releases OpenFOAMŪ 3.0.0 CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 1 November 7, 2015 16:16
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 14:36
OpenFOAM Foundation releases OpenFOAM 2.2.2 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 October 14, 2013 08:18
The OpenFOAM extensions project mbeaudoin OpenFOAM 16 October 9, 2007 10:33
