foam fatal error with pimpleDyMFoam in parallel
Old   June 21, 2017, 04:05
Default foam fatal error with pimpleDyMFoam in parallel
decibelle is on a distinguished road
I ran a case with pimpleDyMFoam in parallel and I have receive this error:
[11] #0  [12] [13] #0  [14] #0  [15] #0  [16] #0  [17] #0  [18] #0  Foam::error::printStack(Foam::Ostream&)[1] #0  [19] #0  [3] #0  Foam::error::printStack(Foam::Ostream&)[5] #0  Foam::error::printStack(Foam::Ostream&)[7] #0  Foam::error::printStack(Foam::Ostream&)[8] #0  Foam::error::printStack(Foam::Ostream&)[9] #0  Foam::error::printStack(Foam::Ostream&)[10] #0  Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)#0  Foam::error::printStack(Foam::Ostream&)--------------------------------------------------------------------------
An MPI process has executed an operation involving a call to the
"fork()" system call to create a child process.  Open MPI is currently
operating in a condition that could result in memory corruption or
other system errors; your MPI job may hang, crash, or produce silent
data corruption.  The use of fork() (or system() or other calls that
create child processes) is strongly discouraged.
The process that invoked fork was:
  Local host:          cfdnode12 (PID 23855)
  MPI_COMM_WORLD rank: 7
If you are *absolutely sure* that your application will successfully
and correctly survive a call to fork(), you may disable this warning
by setting the mpi_warn_on_fork MCA parameter to 0.
Someone know what does it mean?
Thanks in advance
decibelle is offline   Reply With Quote
foam fatal error, parralel, pimpledyfoam
InterDyMFoam+simpleFunctionObject Elham OpenFOAM Running, Solving & CFD 5 July 10, 2017 12:59
[OpenFOAM] Take derivative of mean velocity in paraFoam hiuluom ParaView 13 April 26, 2016 07:44
[snappyHexMesh] Error while running SnappyHex in parallel mg.mithun OpenFOAM Meshing & Mesh Conversion 1 February 10, 2016 14:13
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
