Executing simulation in parallel. orte_init failed
Old   June 15, 2017, 09:56
Default Executing simulation in parallel. orte_init failed
vidyadhar
vidyadhar is on a distinguished road
I have installed openFOAM4.0 and caelus7.04 versions on ubuntu 16.04. I could successfully run openFoam cases in parallel.
But, I am facing the following error when I try to execute my simulation in parallel on caelus7.04. can anyone help me how to execute my simulation in parallel?
[cmg5-Precision-Tower-7810:13568] opal_os_dirpath_create: Error: Unable to create the sub-directory (/tmp/openmpi-sessions-cmg5@cmg5-Precision-Tower-7810_0/50686/0/0) of (/tmp/openmpi-sessions-cmg5@cmg5-Precision-Tower-7810_0/50686/0/0), mkdir failed [1]
[cmg5-Precision-Tower-7810:13568] [[50686,0],0] ORTE_ERROR_LOG: Error in file util/session_dir.c at line 106
[cmg5-Precision-Tower-7810:13568] [[50686,0],0] ORTE_ERROR_LOG: Error in file util/session_dir.c at line 399
[cmg5-Precision-Tower-7810:13568] [[50686,0],0] ORTE_ERROR_LOG: Error in file ess_hnp_module.c at line 320
It looks like orte_init failed for some reason; your parallel process is
likely to abort.  There are many reasons that a parallel process can
fail during orte_init; some of which are due to configuration or
environment problems.  This failure appears to be an internal failure;
here's some additional information (which may only be relevant to an
Open MPI developer):
  orte_session_dir failed
  --> Returned value Error (-1) instead of ORTE_SUCCESS
[cmg5-Precision-Tower-7810:13568] [[50686,0],0] ORTE_ERROR_LOG: Error in file runtime/orte_init.c at line 128
  orte_ess_set_name failed
[cmg5-Precision-Tower-7810:13568] [[50686,0],0] ORTE_ERROR_LOG: Error in file orterun.c at line 694
Last edited by wyldckat; June 25, 2017 at 09:57. Reason: Added [CODE][/CODE] markers
vidyadhar is offline   Reply With Quote
Old   June 29, 2017, 19:10
Darrin Stephens
darrin is on a distinguished road
Hi vidyadhar, your error message appears to be identical to another user (Arka) that we have corresponded with via email. Their problem seemed to resolve itself.
Can you please confirm if your problem has been resolved or is still and issue?
darrin is offline   Reply With Quote
Old   June 30, 2017, 01:13
vidyadhar
Hello Darrin,
Yes the problem got resolved itself.
Arka has somehow did it.
Thanks!!!
vidyadhar
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
Transient boundary conditions Jarrod Sinclair (Sinclair) OpenFOAM Running, Solving & CFD 133 May 6, 2015 07:21
simulation kivatest -parallel simulation vitorspadeto OpenFOAM Running, Solving & CFD 2 April 2, 2014 06:30
OpenFOAM solvers not able to run in parallel raagh77 OpenFOAM Installation 5 November 27, 2013 18:05
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
