defining BC properly in CHT
Old   June 10, 2017, 08:12
Default defining BC properly in CHT
Houssam
houss is on a distinguished road
Send a message via Skype™ to houss
Hello Foamers,
i am trying to simulate a very easy CHT-case including Alu-cover and a cooling pad. the cover is mounted over an alu-case housing a PCB which has MOSFETs mounted on it. Obviously these bad guys are pumping lot of heat (13W)
I am trying in a first run to only simulate the cover, the pad and the surrounding free air (see link attached plz/ Te cover geometry willbe changed later in order to grant more heat exit). Now after trying the set-up the case and getting it running it still break up very early. Following the solver progress i noticed that solving the h-equation for cover and air is taking a lot of time (too many iteratiosn up to 280) with very bad residual.
For this reason i am doubting i defined the BC in bad way.
I'd be grateful for any help guys :-)
I am using OF-v1612+.
https://1drv.ms/u/s!Av2DChjC-94wjqUNk8tP9VCMp6PD4g
Peace.
Houssam.
houss is offline   Reply With Quote
CHT with a moving solid TCosta CONVERGE 5 August 30, 2016 16:52
vof with cht klilla OpenFOAM Programming & Development 2 July 29, 2015 06:30
Defining one surface in 2 domains MGabr CFX 1 November 13, 2013 05:48
Overflow Error Because of defining a New Coordinate Frame ashtonJ CFX 3 April 23, 2012 09:08
Expert-param:: Cht diffusion scheme PCFD CFX 4 July 12, 2010 14:49
