A problem of incorrect fluid flow field using Openfoam
Like Tree3Likes
Old   June 11, 2017, 09:15
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
@marialhm
Not sure if I get your set up correctly BUT your case is physically unstable, so your results will depend on mesh, discretisation schemes, linear solvers, convergence criteria, turbulence model etc.
I have created example case - https://github.com/mrklein/foam-cases/tree/master/jet - for pimpleFoam. And the results strongly depend on time discretisation and turbulence model.
Here is standard k-epsilon:
Here is k-omega SST
With laminar and realizable k-epsilon (and Crank-Nicolson) we can resolve instability near inlet:
Videos of simulations are collected here: https://www.youtube.com/playlist?lis...WZo4SmJc78aZL5
cbcoutinho, kostnermo and piu58 like this.
alexeym is offline   Reply With Quote
Old   June 11, 2017, 23:29
Maria
marialhm is on a distinguished road
Originally Posted by dferrando View Post
You could try with symmetry boundary condition.
Thanks, I will try.
marialhm is offline   Reply With Quote
Old   June 11, 2017, 23:52
Arjun
arjun will become famous soon enougharjun will become famous soon enough
Originally Posted by alexeym View Post
@marialhm
Here is k-omega SST
Something similar but with mixture multiphase (FVUS Wildkatze) (Notice how unsymmetric it becomes later, but it is transient simulation).
https://www.youtube.com/watch?v=v_y8VejlklQ
arjun is offline   Reply With Quote
Old   June 12, 2017, 00:36
Maria
@marialhm
Here is k-omega SST
Many thanks!!! I watched your video, I got the same results with you, that's why I'm confused.
Old   June 12, 2017, 00:39
Maria
@marialhm
Here is k-omega SST
How can I download your code files?
Old   June 12, 2017, 03:34
Alexey Matveichev
You download foam-cases (https://github.com/mrklein/foam-case...ive/master.zip) repository and take jet from there. Or you can clone repository with git instead of downloading zip.
Setting time varying flow field in OpenFOAM Tings_ OpenFOAM Pre-Processing 5 May 8, 2017 11:21
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
Fluid Flow over a bus -- Convergence Problem Roberto J. STAR-CCM+ 2 May 12, 2016 14:05
Problem with an old Simulation FrankW CFX 3 February 8, 2016 05:28
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
