Could you comment on some valgrind out I get from OpenFOAM-2.3.x
Old   June 6, 2017, 16:06
Default Could you comment on some valgrind out I get from OpenFOAM-2.3.x
Victor Koppejan
vkoppejan is on a distinguished road
I have a code based on openfoam-2.3.x (Could be ported to newer version but,.... the usual excuses).
When I put it through valgrind I get the following messeages. Any thoughts and comments. Code seems to run fine normally.
I run a centos7 48 core shared mem system, 12 mpi ranks, gnu compilers and openmpi-1.8.8.
Thanks in advance for your help.
Victor
==10049== Invalid read of size 4
==10049== at 0xB393EA0: opal_os_dirpath_create (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
==10049== by 0xB0EB045: orte_session_dir (in /opt/ud/openmpi-1.8.8/lib/libopen-rte.so.7.0.6)
==10049== by 0xB0FF764: orte_ess_base_app_setup (in /opt/ud/openmpi-1.8.8/lib/libopen-rte.so.7.0.6)
==10049== by 0x1074D519: rte_init (in /opt/ud/openmpi-1.8.8/lib/openmpi/mca_ess_env.so)
==10049== by 0xB0DD2D7: orte_init (in /opt/ud/openmpi-1.8.8/lib/libopen-rte.so.7.0.6)
==10049== by 0x6FF66BC: ompi_mpi_init (in /opt/ud/openmpi-1.8.8/lib/libmpi.so.1.6.3)
==10049== by 0x70162BA: PMPI_Init (in /opt/ud/openmpi-1.8.8/lib/libmpi.so.1.6.3)
==10049== by 0xA5D8A86: Foam::UPstream::init(int&, char**&) (UPstream.C:64)
==10049== by 0x93C9F61: Foam::ParRunControl::runPar(int&, char**&) (parRun.H:71)
==10049== by 0x93C513F: Foam::argList::argList(int&, char**&, bool, bool, bool) (argList.C:393)
==10049== by 0x47E669: main (setRootCase.H:5)
==10049== Address 0x1198d480 is 48 bytes inside a block of size 51 alloc'd
==10049== at 0x4C27BBD: malloc (vg_replace_malloc.c:296)
==10049== by 0xB393E52: opal_os_dirpath_create (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
Last edited by vkoppejan; June 6, 2017 at 16:38. Reason: additional info on system used, changed to full debug output
vkoppejan is offline   Reply With Quote
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology wyldckat OpenFOAM 17 November 10, 2017 16:54
OpenFOAM 4.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 2 October 6, 2017 06:40
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 04:19
[swak4Foam] Installing OpenFOAM 2.3.x and swak4Foam on Mac Yosemite 10.10.5 ajonuz OpenFOAM Community Contributions 9 October 24, 2015 13:11
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
