June 5, 2017, 14:16 |
Problem in fireFoam - Co vs. T_max
Rep Power: 14 |
i'm trying to get used to the fireFoam solver in OF 4.X. I created a small test case of a rectangular shape. I used the 3Dfirepool tutorial test case files and set it to laminar. Now if i simulate 5 sec of real time and try different maxCo, i get different T_max temperatures at the end of the run (=5 sec). In total the variance is almost 380K between my max Co of 0.5 and the min Co of 0.01. (see graph) Also i get non strictly growing temperatures T_max with decreasing maxCo, which i think is odd. 1) Can anybody suggest why the difference in combustion temperatures exists? 2) Why is there "hole" around maxCo 0.1 and 0.03? 3) Most importantly, which Time step should i choose? Last edited by BlnPhoenix; June 14, 2017 at 05:24. |
June 12, 2017, 12:32 |
Joshua
Rep Power: 10 |
Have you tried a more refined mesh or running it to 10s to see if that changed anything?
Disclaimer, I have very little experience with fireFoam. I find this interesting. Joshua |
June 12, 2017, 13:35 |
Rep Power: 14 |
Thanks for your suggestion, Joshua! I will try to refine the grid and check back.
[Other] engineFoam new mesh problem | ayhan515 | OpenFOAM Meshing & Mesh Conversion | 5 | August 10, 2015 09:45 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 05:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 06:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 07:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 20:13 |
