Incomplete ring MRF zones
Old   June 2, 2017, 05:14
Default Incomplete ring MRF zones
Attesz's Avatar
Attesz
Attesz is an unknown quantity at this point
Dear all,
I have a case with an MRF zone that is diverging but only after 2000 iterations. It is a high pressure regenerative turbine pump. In one section of the pump the MRF zone is discontinued, so the MRF "ring" is not a complete ring but only a 270deg section.
As MRF is just adding a tangential velocity to the flow I assume this should not introduce divergence problems. Am I right? Can the MRF zone be "incomplete ring"?
Thanks
Attesz is offline   Reply With Quote
Old   June 3, 2017, 06:16
Hrvoje Jasak
The outside surface of the MRF zone must be a body of rotation - that's all.
If you have cyclics on tour 270 deg segment, all is well.
I run tirbomachinery CFD with FOAM like that all the time. For validation studies look at
www.fsb.hr/cfd
under Dissemination - Master Theses
Hrvoje Jasak
mrf
MRF solvers give diffenrent results when MRF zone's diameter is different sharonyue OpenFOAM Running, Solving & CFD 10 May 31, 2022 05:46
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
Nested MRF zones? lordvon OpenFOAM Running, Solving & CFD 0 August 17, 2013 18:10
Problems building Paraview 3.12 on Gentoo Linux pajot OpenFOAM Installation 11 April 11, 2013 09:09
[swak4Foam] installing funkySetFields igo OpenFOAM Community Contributions 1 November 20, 2012 21:16
