Ignition with PaSR
Old   May 30, 2017, 06:48
Default Non premixed Ignition with PaSR
SM
canopus is on a distinguished road
Trying to run counterFlowFlame2D with PaSR combustion model instead of laminar using Ofdev version.
Firstly, I have run the tutorial with laminar model and copied the final solution to 0. Then I change the combustionProperties to following
combustionModel  PaSR<psiChemistryCombustion>;
active  true;
PaSRCoeffs
    Cmix                1.0;
    turbulentReaction   banana;//doesn't matter?
    useReactionRate     banana;//doesn't matter?
However, the temperature keeps on dropping till it reaches 293K,
the inlet fuel and air temperature.
So it looks that the ignition did not occur.
Can anyone comment what is going wrong here?
The case files are attached.
canopus is offline   Reply With Quote
Old   June 5, 2017, 06:34
Lasse Brams Vinther
Swagga5aur is on a distinguished road
Hello SM,
I believe the issue is the adaption from laminar to PaSR, as PaSR is a turbulent combustion model determining a finite combustion rate based upon the turbulent and chemistry time scales.
I have attached a not thoroughly tested case, based upon the counterflowflame2d case from OF4.1, with the added turbulent property changes.
Note that the turbulent properties are just guess values.
Swagga5aur is offline   Reply With Quote
combustion, ignition, pasr
Ignition and flame propagation with XiFoam for a few meters long comput. domains Gloq OpenFOAM Running, Solving & CFD 1 February 21, 2023 13:22
How can I define whether ignition is successful in PaSR model sy2516 OpenFOAM Running, Solving & CFD 0 March 10, 2017 01:18
Premixed flame ignition energy Londo Main CFD Forum 0 July 13, 2015 11:57
how does the ignition model initiate main combustion mepgzzi Siemens 0 June 23, 2012 15:32
Ignition modeling Julie Polyakh Siemens 0 May 20, 2004 09:05
