May 27, 2017, 21:49 |
Problem with the bc of wind tunnel
Thodoris
Rep Power: 10 |
Hello foamers,
I am running a simulation in openfoam for a flow over two 3d wings in order to see the corotating vortex behind the wings. I have made my mesh using snappyhexmesh and I have checkmesh it. I run with simple foam and spalartalmaras ddes but my solution doesn't converge. So I think the problem is with the boundaries conditions. I have four boundaries inlet outlet walls(the wind tunnel) and wings. For the walls I first used the symmetry boundary condition and then I used no slip conditions but in both cases I didn't have satisfactory results. Does anyone have an idea for the boundary condition I have to use?. Thank you very much in advance! Thodoris |
May 28, 2017, 01:24 |
Milad
Rep Power: 10 |
Hi teodm
I have a question for you is simplefoam capable of using LES type turbulence models? Cause I think simplefoam isn't transient solver! I think Pimplefoam is a suitable solver for your case. Sent from my iPhone using CFD Online Forum mobile app |
May 28, 2017, 05:35 |
Thodoris
Rep Power: 10 |
Hi Milad,
Thank you very much for your answer. I found it in the tutorials of airfoil2d I think, simplefoam along with LES |
May 29, 2017, 04:54 |
Thodoris
Rep Power: 10 |
I have also run with komega SST and spalart almaras but comparing the three results the sa-DDES are the ones closer to the experimental but still not as much close as i want to.That's why i think the problem has to be with the boundary conditions of the wind tunnel.If anyone could lead me to something it would be very helpful
wind turbine simulation inside the wind tunnel | shaohua | FLUENT | 4 | April 11, 2014 18:01 |
Rotate part in wind tunnel | andr3s_diaz | STAR-CCM+ | 5 | November 5, 2013 09:52 |
how to consider perforated wind tunnel wall in CFD simulation | littlelz | CFX | 4 | June 11, 2009 06:51 |
Simulating a Göttingen type wind tunnel in FLUENT | Chris | FLUENT | 3 | December 4, 2006 18:33 |
defining velocity profile in a wind tunnel model | Erdem | FLUENT | 0 | June 20, 2006 14:00 |
