May 24, 2017, 07:46 |
Latest time compatibility problem
Juan Blanco
Rep Power: 9 |
I ran a case in steady-state until its convergence. After that, I tried to run the same exact case but from the latest time (from the previous simulation). However, it seems that the results re-converged into the same value, i.e, the system is initialize with the file of the latest times, it changes a bit and evolves into the previously converged solution. If anybody has an idea of why can this be happening I'd like to know. Regards, Juan Blanco |
May 24, 2017, 09:27 |
Juan Blanco
Rep Power: 9 |
I forgot to tell that the following message appears in the start up of the case
Warning: bounding density to 1.0 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 22:40 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
