May 23, 2017, 13:41 |
Boundary conditions free surface
oum
Rep Power: 9 |
I am new user of OF-2.3.0 and I am trying to create a free surface in the propeller tutorial but when I trying to do decomposePar I get this error. I know it has to do with the boundary condition at the inlet, but I do not know how to fix it. Can anyone help please? the error: Code:
Build : 2.3.0-f5222ca19ce6 Exec : decomposePar Date : May 23 2017 Time : 12:18:47 Host : "Mojave.HPC.MsState.Edu" PID : 8993 Case : /cavs/users/oumnia/test15may/propeller nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Decomposing mesh region0 Create mesh Calculating distribution of cells Selecting decompositionMethod hierarchical Finished decomposition in 0.25 s Calculating original mesh data Distributing cells to processors Distributing faces to processors Distributing points to processors Constructing processor meshes Reading hexRef8 data : cellLevel Reading hexRef8 data : pointLevel Reading hexRef8 data : level0Edge Processor 0 Number of cells = 131396 Number of faces shared with processor 1 = 2766 Number of processor patches = 1 Number of processor faces = 2766 Number of boundary faces = 464 Processor 1 Number of cells = 131396 Number of faces shared with processor 0 = 2766 Number of faces shared with processor 2 = 6482 Number of processor patches = 2 Number of processor faces = 9248 Number of boundary faces = 14411 Processor 2 Number of cells = 131396 Number of faces shared with processor 1 = 6482 Number of faces shared with processor 3 = 8780 Number of processor patches = 2 Number of processor faces = 15262 Number of boundary faces = 22186 Processor 3 Number of cells = 131398 Number of faces shared with processor 2 = 8780 Number of processor patches = 1 Number of processor faces = 8780 Number of boundary faces = 25566 Number of processor faces = 18028 Max number of cells = 131398 (0.00114158% above average 131396) Max number of processor patches = 2 (33.3333% above average 1.5) Max number of faces between processors = 15262 (69.3144% above average 9014) Time = 0 --> FOAM FATAL IO ERROR: size 0 is not equal to the given value of 652 file: /cavs/users/oumnia/test15may/propeller/0/alpha.water.boundaryField.inlet from line 32 to line 37. From function Field<Type>::Field(const word& keyword, const dictionary&, const label) in file /usr/local/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/Field.C at line 292. FOAM exiting Code:
FoamFile { version 2.0; format ascii; class volScalarField; object alpha.water; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { wall { type zeroGradient; } inlet { type inletOutlet; inletValue uniform 0; value uniform 0; } outlet { type zeroGradient; } AMI1 { type cyclicAMI; value uniform 0; } AMI2 { type cyclicAMI; value uniform 0; } } |
boundary condition, error, free surface, propeller |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
Boundary conditions on free water surface | Per | OpenFOAM Running, Solving & CFD | 4 | October 16, 2012 03:31 |
