URANS 2D Square Cylinder Problems
Old   May 23, 2017, 14:18
Default URANS 2D Square Cylinder Problems
and_user is on a distinguished road
Dear Community,
I found a strange behavior on some URANS bluff body aerodynamics simulations that I am carrying out.
I am studying the square section geometry in 2D. The Reynolds number based on the cross-section is 75600.
The Cartesian geometry is created with blockMesh (OF3.0). The use of such mesh generator prevent from the mesh skewness and non-orto problems. The domain is very wide, so I got no problems of reflection or blockage. The mesh resolution is very accurate (from 60k to 250k cells), because the aim is the use of SA model and kw-SST model WITHOUT wall functions (low-Re). With my mesh I reach a y+ max (locally, at the edges) between 4 and 2 depending on the mesh accuracy. n_w/D ranges between 6e-4 for the coarsest mesh and 3.5e-4 for the finest one. The stretching factor is at least 1.3.
I use OF 2.3.1 to solve the equations.
To interpolate the discretized RANS equation terms I use second-order schemes such as:
linearUpwind for div(phi,U) term
linearUpwind for the turbulence model transport term(s)
linear for the diffusive term
I solve the equations with the PIMPLE pressure-velocity algorithm. The iterations advances in time with the backward second-order scheme. The time step varies according to the maxCo imposed at any iteration.
I carried out a lot of simulations, but I would like to ask your opinion.
It seems that the numerical solution of the problem could converge to two distant solutions: one in good agreement with the experimental results (CD=2.1, St=0.125, CL'=1.5), one far away from it (CD=2-2.4, St=0.09-0.1(!!!), CL'=1.3-1.8). In particular I noticed:
- With the SA model: with coarse mesh and large time step the solution converges to the expected. Increasing the mesh resolution or reducing the time step (down to maxCo=1) the model seems to miss some additional numerical viscosity and converges to a solution (with Strouhal = 0.09) far away from the experimental one expected.
- With the kw-SST model: I found more problems than with the SA. Also for coarser grids or larger time step the solution converges to the same values above mentioned far away from the expected one.
It is a long time I am trying to vary all the possible parameters: mesh generator, numerical schemes, OF version, etc.
I am struggling with the interpretation of these results. I would like to ask your opinion, especially from OF expert.
I apologize for disturbing you, but I am not so good reading the code and maybe there is something there that I am missing.
Sincerely,
Andrea
and_user is offline   Reply With Quote
Old   May 23, 2017, 15:04
tareqkh's Avatar
CFD
tareqkh is on a distinguished road
What values did you use for k and omega when you used komegaSST? I guess generally the problem similar to that if you replace the square by a cylinder in terms of physics.
Best,
tareqkh is offline   Reply With Quote
Old   May 24, 2017, 02:09
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
With the coarse mesh you have the wall function working. If you finer the mesh an lower the tim step the wall function works to a much lesser degree: That is the difference I see.
Nevertheless, the close to DNS simulation should get reasonable results too. But I think that is the direction you should look for what is different.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   May 24, 2017, 10:46
Dear tareqkh,
if you mean the k and omega values at the surface, I employed the values suggested in Menter's paper for omega, while I set k very small (1e-20).
Please, can you explain better your statement "generally the problem similar to that if you replace the square by a cylinder in terms of physics"?
Thank you
Old   May 24, 2017, 10:49
Dear piu58,
as I wrote in the main message I do not use wall function. I mean, I do not set any wall function in the dict files. Are there some WF in the code working irrespectively to my numerical set up?
You wrote "the close to DNS simulation should get reasonable results too", but how can I perform DNS in a two-dimensional domain?
Thank you
Old   May 24, 2017, 22:01
tareqkh's Avatar
CFD
Originally Posted by and_user View Post
Dear tareqkh,
Thank you
Dear and_user,
Well, you should expect von karman vortex according to your Reynolds number. Please have a look at the following link http://www.mediafire.com/file/wyf8w1...dyCylinder.pdf. I created this document a long time ago for the laminar flow over a cylinder. You might find it helpful at the same time you might find some typo here and there etc. I still have the case files as well. By the way, what is your wall distance? How fvSchemes looks like in your case?
Regards,
aerodynamics, bluff body wake, square, urans
Flow over square Cylinder alireza_b FLUENT 8 February 5, 2014 05:16
[snappyHexMesh] snappyHexMesh - 2D Cylinder Problems Logan Page OpenFOAM Meshing & Mesh Conversion 4 May 27, 2013 13:07
[snappyHexMesh] 2D Cylinder mesh problems with Snappy ivan_cozza OpenFOAM Meshing & Mesh Conversion 37 June 4, 2012 16:49
LES of a square cylinder gfilip OpenFOAM Running, Solving & CFD 1 June 24, 2010 13:33
Cylinder head port problems Jon Reynolds FLUENT 0 March 23, 2006 09:38
