May 18, 2017, 05:41 |
K (turbulent kinetic energy) ground(wall) BC
rmz
Rep Power: 9 |
I am working on a simulation of wind on buildings. I am using a RASModel kEspilon with the simpleFoam solver. I am applying ABL (atmospheric boundary layer) conditions. for the "ground" patch of my domain the boundary condition of K is KqRWallFunction, but I am not sure which value should I use. in most of the tutorials they apply the same value as the internal field but in the turbineSiting tutorial they applied uniform 0. so for the K on the ground patch should I apply KqRWallFunction - value: uniform 0 or KqRWallFunction - value: same as internalField thank you for your help. |
May 19, 2017, 04:31 |
For the value for a derived boundary condition (such as wall functions) usually the value entry is only a placeholder. It may get used in the first iteration if some value is needed, but usually a value will be set as soon as the boundary condition is updated. This means most of the time as long as the value is physical it does not matter too much what this value is. There may be some rare cases where there is an influence, but I would not know one by heart. In your case I would use the internalField value, but I doubt you will find much difference if you use 0. Regards, Tom |
May 23, 2017, 03:28 |
rmz
Rep Power: 9 |
thank you Tom for your help. now I understand how it works. for information, I did 2 simulations with different initial K conditions (as stated in post #1) and obtained the same results. Best Regards |
abl flow, boundary condition, building aerodynamics, turbulent kinetic energy, wall boundary condition |
How to obtain turbulent kinetic energy data from LES model of Ansys CFX? | rsin | CFX | 19 | December 29, 2018 04:43 |
Turbulent Kinetic Energy for a one-equation model | wgvanveen | Main CFD Forum | 0 | March 25, 2015 06:26 |
LES and total turbulent kinetic energy | Boerge | FLUENT | 1 | September 8, 2012 11:41 |
what's the meaning of turbulent kinetic energy? help!!! | syd | STAR-CCM+ | 1 | August 31, 2010 09:22 |
sgs turbulent kinetic energy | blons | Main CFD Forum | 0 | February 25, 2010 12:16 |
