Create free-surface OPENFOAM
Old   May 15, 2017, 13:33
Default Create free-surface OPENFOAM
oum
oumnion is on a distinguished road
Hi, I am new OpenFOAM-2.3.0 user, and I would like to create a free surface application for the OpenFOAM propeller tutorial (pimpleDyMFoam).
I copied all the files into damBreakWithObstacle (interDyMFoam). But I when I tried to run it it didn't work.
Can you please help me? Thank you.
oumnion is offline   Reply With Quote
Old   May 15, 2017, 14:07
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
What happens?
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   May 15, 2017, 14:14
oum
Mojave[22] oumnia$ ./Allrun
Running blockMesh on /cavs/users/oumnia/test10may/damBreakWithObstacle
Running topoSet on /cavs/users/oumnia/test10may/damBreakWithObstacle
Running subsetMesh on /cavs/users/oumnia/test10may/damBreakWithObstacle
Running setFields on /cavs/users/oumnia/test10may/damBreakWithObstacle
Running interDyMFoam on /cavs/users/oumnia/test10may/damBreakWithObstacle
Mojave[23] oumnia$
it stopped and I didn't get any files
Old   May 15, 2017, 15:04
oum
What happens?
I have this error message:
-> FOAM FATAL ERROR:
Unable to find cellZone innerCylinderSmall.  Valid celLZones are:0()
    From function solidBodyMotionFvMesh::solidBodyMotionFvMesh(const IOobject&)
    in file solidBodyMotionFvMesh/solidBodyMotionFvMesh.C at line 107.
FOAM exiting
Old   May 16, 2017, 01:19
piu58's Avatar
Uwe Pilz
You mixed two tutorials. Fro very sure the are thing wihci does not fit. I recommend building your case from one of the tutorials step by step.
Uwe Pilz
Old   May 17, 2017, 15:39
oum
Thank you for your advice, I started my case from scratch and followed step by step. But I encountered an error (below) I changed my delta T to 0.001 but the error is still here. Should I increase the delta T ? or is the problem located somewhere else ?
Interface Courant Number mean: 0 max: 0
Courant Number mean: 2.91152e+09 max: 8.88429e+14
deltaT = 9.53168e-25
Time = 0.0004216348
PIMPLE: iteration 1
solidBodyMotionFunctions::rotatingMotion::transformation(): Time =  0.000421635 transformation: ((0 0 0) (0.999445 (0 0.033303 0)))
AMI: Creating addressing and weights between 18496 source faces and 18720 target faces
AMI: Patch source sum(weights) min/max/average = 0.916856, 1.04568, 1.00017
AMI: Patch target sum(weights) min/max/average = 0.881389, 1.00313, 0.99972
Execution time for mesh.update() = 0.92 s
--> FOAM Warning :
    From function Time::operator++()
    in file db/Time/Time.C at line 1055
    Increased the timePrecision from 7 to 8 to distinguish between timeNames at time 0.000421635
MULES: Solving for alpha.water
Phase-1 volume fraction = 0  Min(alpha1) = 0  Max(alpha1) = 0
--> FOAM Warning :
    Increased the timePrecision from 8 to 9 to distinguish between timeNames at time 0.000421635
--> FOAM Warning :
    Increased the timePrecision from 9 to 10 to distinguish between timeNames at time 0.000421635
--> FOAM Warning :
    Increased the timePrecision from 10 to 11 to distinguish between timeNames at time 0.000421635
smoothSolver:  Solving for Ux, Initial residual = 0.882579, Final residual = 0.0239247, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 0.989251, Final residual = 0.0733787, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 0.967456, Final residual = 0.0495307, No Iterations 1
GAMG:  Solving for p_rgh, Initial residual = 1, Final residual = 0.00672032, No Iterations 23
time step continuity errors : sum local = 1.70523e-08, global = -7.09543e-11, cumulative = 19.4836
PIMPLE: iteration 2
smoothSolver:  Solving for Ux, Initial residual = 0.999984, Final residual = 0.000695704, No Iterations 1000
smoothSolver:  Solving for Uy, Initial residual = 0.999998, Final residual = 0.000186351, No Iterations 1000
smoothSolver:  Solving for Uz, Initial residual = 0.999979, Final residual = 0.000476591, No Iterations 1000
GAMG:  Solving for p_rgh, Initial residual = 0.519928, Final residual = 6.59757e-09, No Iterations 43
time step continuity errors : sum local = 0.0544684, global = -0.000174176, cumulative = 19.4834
smoothSolver:  Solving for epsilon, Initial residual = 1, Final residual = 5.18751e-07, No Iterations 23
smoothSolver:  Solving for k, Initial residual = 0.999589, Final residual = 9.63686e-07, No Iterations 33
bounding k, min: 1.79934e-46 max: 1.45648e+58 average: 5.43587e+54
ExecutionTime = 312.41 s  ClockTime = 351 s
free surface, openfoam 2.3.0, propeller, tutorial
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology wyldckat OpenFOAM 17 November 10, 2017 16:54
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 07:15
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 04:19
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
